Raster Centering Rings anyone got them?
incova
Posted: Sat Dec 24, 2011 2:53 pm    Post subject: Raster Centering Rings anyone got them?
I have heard of these and considering the amount of electronic shift of the raster I have to use to get 1080p on my PJ I have to ask where so you get them, I hate stressing the electronic to extremes.?
The more I learn
the less I know.
tse
Posted: Sat Dec 24, 2011 4:40 pm    Post subject:
Raster centering rings are the same as the two pole rings that are used for setting flair or beam centering. They just need to be located between the deflection yoke and the focus magnet.
Scott
Thomas Jefferson
incova
Posted: Sat Dec 24, 2011 4:51 pm    Post subject: Great
Thanks again Scott, I figured it was a magnet like those but I thought perhaps it had a higher or lower level of intensity compared to the astig magnets, so this means I can remove the magnets on my 4300 and use them as vertical horizontal raster control magnets, great stuff! It just means stripping the tube down to the deflection yoke not too bad. I remember you talking to Alan about it but nothing was said of being able to use Astig magnets instead of the specific magnets Alan had.
The more I learn
the less I know.
incova
Posted: Sat Dec 24, 2011 5:00 pm    Post subject: or
I am interpreting this correctly I hope, that Astig magnets can be used as raster centering magnets?
I just assumed thats what you meant as I have spare sets of 4 pole astig magnets which I assumed would allow me control of the raster both vertically and horizontally?
The more I learn
the less I know.
tse
Posted: Sat Dec 24, 2011 5:15 pm    Post subject:
The right type are the two pole ones in the ring pack not the four or six pole stig rings. The problem with using them is there isn't enough room between the deflection yoke and the focus magnet for the rings and the clamp for the tube neck. You could use the rings if you can find a way to mount them without seperating the deflection yoke and focus magnet too much.
Scott
Thomas Jefferson
Posted: Sat Dec 24, 2011 6:21 pm    Post subject:
Scott
What a great idea. Wish I had thought of that Laughing
incova
Posted: Sat Dec 24, 2011 7:20 pm    Post subject: Hi Chip
You posted about this years ago if I remember right, it was on your list of upgrade for the 4600, paint job, marquee optics, modded neckboard, I have it saved somewhere, just could not find out about the raster rings specifically.
The more I learn
the less I know.
incova
Posted: Sat Dec 24, 2011 7:26 pm    Post subject: ok found it/
Found the thread its on AVS, lots of good stuff there wish we could just download the lot.
http://www.avsforum.com/avs-vb/showthread.php?t=628463&page=15
The more I learn
the less I know.
Posted: Sat Dec 24, 2011 7:36 pm    Post subject:
Some sets, like the NEC PG series and the DWINs have additional rings right on the main deflection yoke that act as a global raster shift. No idea if they can be adapter to work on a Marquee or BArco, but I'm about to throw out some DWIN yokes if you want them. The yokes have burned pins on the connectors, but the rings work fine.
incova
Posted: Sat Dec 24, 2011 7:50 pm    Post subject: Thanks Curt!
Thanks Curt!, that would be great.
The more I learn
the less I know.
tse
Posted: Sun Dec 25, 2011 1:06 am    Post subject:
stefuel wrote:
Scott
Yep, you came up with a pretty inovative way to mount the rings to the deflection yoke. I could never figure out how to magnetize the thin steel rings that would have worked really well. I watched someone magnetize the rings many years ago and it was very simple. I tried to do the same thing but couldn't get it to work.
Scott
Thomas Jefferson
tse
Posted: Sun Dec 25, 2011 1:08 am    Post subject:
The rings will probably work just fine. The tough part is the mechanical mounting.
Scott
Thomas Jefferson
tse
Posted: Sun Dec 25, 2011 1:11 am    Post subject:
The Ampro factory trick for centering the raster was to rotate the focus magnet on the tube neck. That usually would work good enough to get the raster where you want without using alot of registration shift. The deflection shift is ok to use.
Scott
Thomas Jefferson
incova
Posted: Sun Dec 25, 2011 1:52 am    Post subject: Hi again
I did use the focus magnets Scott but still have to use a lot of horizontal shift, from that exchange with Chip I take it he found a way to mount it directly on the deflection yoke so focus of the beam would not be a issue due to moving the focus magnet too far back, care to share some wisdom Chip?!
The more I learn
the less I know.
tse
Posted: Sun Dec 25, 2011 4:56 pm    Post subject:
Don't worry too much about using the horizontal shift. That is what it is there for. Static vertical shift and red/blue static vertical shift (40 and 41 code) is okay to use. Try to avoid using the registration (dynamic) shift.
Scott
Thomas Jefferson
dvh99
Posted: Sun Dec 25, 2011 9:55 pm    Post subject:
since you are using a certain amount of backporch the trick is to center the active image instead of the raster without using static shift.
you have the focus and astig magnets setup correctly when the grid doesn`t move while focussing.
if astig is setup incorrectly it attenuates vertical or horizontal resolution or both severely.
but astig messes with the focus coil ideal position and that messes with the astig...... you get the idea, it`s fine tuning until you get it just right.
just realised i`m a member now 2 years exactly Cool .
incova
Posted: Sun Dec 25, 2011 10:08 pm    Post subject: k
Thanks again Scott I will check those setting and try not to use the dynamic shift. Hi Dennis!, I am redoing the magnetics on my PJ should have a set of 6 pole astig magnetics soon, then I will just focus on Astig until I get it done right, might take me a week or so.
Thanks for the messages guys on Christmas day no less!
The more I learn
the less I know.
