| Posted: Thu Dec 15, 2011 6:07 pm Post subject: OK, this is a new one (NEC PG) |
So I repaired a system board and other boards out of an NEC PG that's located in the UK. Seems like the system board took a dump again right after he got them back.
He says that the system board is a PWC 3716..... never heard of that. The ones I've seen are PWC 3717. Typo, or does it exist?
| Posted: Thu Dec 15, 2011 6:25 pm Post subject: |
3716 is the video out pwr board.
| Posted: Fri Dec 16, 2011 6:01 am Post subject: |
Yes indeed, 3716, that is the board with the big heat sink and the big long row of pots that you just dont touch...
All 5 system boards i have here are 3717, GAIN CTL board is 3715, WAVE is 3719...
Maybe he is saying the system board as in he thinks they are ALL system boards cause they are inside the system?
kschmit2
| Posted: Fri Dec 16, 2011 2:38 pm Post subject: |
I attached a list of board numbers that I compiled. It reflects the PG9000, GE 901(E) and PG6100
The GE 901(E) is a rebadged PG9000 that came in an all-black case.
Kai
| Description: |
 Download |
| Filename: |
NEC PG Parts.pdf |
| Filesize: |
9.61 KB |
| Downloaded: |
22651 Time(s) |
| Posted: Sat Dec 17, 2011 11:02 pm Post subject: |
Well that is quite handy, thankyou very much for posting that
