incova
| Posted: Thu Dec 08, 2011 12:54 am Post subject: Drilling into a Ampro 4600 LC Chamber to mount lens? |
Getting the top or bottom of the picture totally perfect is very difficult with a Ampro due to the way the lens are mounted on plates, I was wondering if you could drill directly into the LC chambers and mount the lenses directly to the chambers? I imagine the answer is probably no as this would mean the chambers would leak or you would be drilling to close or into the glycol chamber? I dont ever remember reading a thread on this but then my memory sucks...............
Just wondering out loud.
I am guessing Chip and others already thought better of this and just replaced the LC chamber with another brand?
the less I know.
| Posted: Thu Dec 08, 2011 1:29 am Post subject: |
Don't do it.
The combination of lower projection angle and widescreen image reduces the bad focus effect. If you were to shoot a zero projection angle you would have no corner focus issues.
I did design a set of top and bottom plates to squeeze in a set of Marquee optics but never got around to doing it. I no longer have the desire to play mod boy with CRT projectors. I just don't have the time for it.
_________________ Chip
incova
| Posted: Thu Dec 08, 2011 1:33 am Post subject: K |
Thanks Chip, for some reason I thought you had done it, as you say with widescreen material you will never see the issue, I was curious to see if someone had done it.
the less I know.
| Posted: Thu Dec 08, 2011 5:53 pm Post subject: |
You running 4:3 over there?
incova
| Posted: Thu Dec 08, 2011 7:36 pm Post subject: hey |
Yup, got a few movies which are 4.3, I have the PJ pretty low down of the ceiling, well as low as I could get it so the problem has not been too bad but I had issues which I wanted to resolve.
the less I know.
| Posted: Fri Dec 09, 2011 5:30 am Post subject: |
4:3, Cool!
Issues? With an Ampro? hehe
I had mine on last night. It's developed a tic. It overheats with the case on. Good thing it's winter. I'll have to pipe some cold air in to chill it.
4:3, Cool!
