olakjen
| Posted: Mon Dec 05, 2011 7:34 pm Post subject: BLENDING 2 G70's |
Hello I gone mount 2 g70 in a blend setup, will it be a big deferent to use 2 g90 instead ore some odder 9inch machine
a may be want to bye hirez tubes for the g70
olakjen
| Posted: Mon Dec 05, 2011 8:11 pm Post subject: |
ok thank you , i need all the tubes , do you know if it does make a big deferent if i bye hires tubes ,when it gone be used in a blend?
| Posted: Mon Dec 05, 2011 8:34 pm Post subject: |
What will be your main source? Blu Ray satellite etc? Blending is best used for 2.4( scope) material.
My tubes are not High res but it wouldn't hurt having them, and the ones from Greg Eiseman are not that much more than other new tubes.
A little more info on what your using for source, blend, screen size etc would be helpful.
| Posted: Mon Dec 05, 2011 11:09 pm Post subject: |
Hi olakjen, would it be OK if I changed this thread tittle to "BLEND G70'S"?
Jeremy
olakjen
| Posted: Mon Dec 05, 2011 11:24 pm Post subject: |
| AnalogRocks wrote: | Hi olakjen, would it be OK if I changed this thread tittle to "BLEND G70'S"?
Jeremy |
ok thats fine
olakjen
| Posted: Mon Dec 05, 2011 11:35 pm Post subject: |
| Nashou66 wrote: | What will be your main source? Blu Ray satellite etc? Blending is best used for 2.4( scope) material.
Athanasios |
ok it is 2g70 and i am using the tvone c2-2450 units, the videochain is one lumagen radiance xe 3d+ , hdmi splitter ,videoeq pro , tvone , moome IFB card, screen is 2.4 120 inch. and it is mostly movies a use it for.
do you use ycbcr 422 if so howe do you du that?
a can only use 444 and RGB
| Posted: Mon Dec 05, 2011 11:45 pm Post subject: |
| olakjen wrote: | | Nashou66 wrote: | What will be your main source? Blu Ray satellite etc? Blending is best used for 2.4( scope) material.
Athanasios |
a can only use 444 and RGB |
I am not using 422 for some reason the TV-ones can not accept that even though they keep telling me it can. Have you tried connecting them up at all to see if you get a picture with Blu Ray? for some reason it does not allow me to get a picture, all I get is snow. so i use the moome MUX-HD as my HDMI splitter to handle the HDCP crap.
So you have two Video Eq's for the CMS? that should work great!!! Now you need Calman v4 with the add on for automation and let the auto calibrate get you close. one thing that is cool about Calman you can add as many shades of grey up to 256 and from what Bob( Boilermaker) has told me you can also do that with the video EQ's so in essence you can calibrate 256 points of % white and its corresponding Gamma!! that would be a perfect blend!!!
And with that amount of control I bet you could even use used tubes id they already have 4:3 wear.
Where are you located olakjen?
