hushbox - cover on or off?
zaphod
Posted: Wed Nov 29, 2006 6:01 pm    Post subject: hushbox - cover on or off?
i'm getting close to the hushbox stage of the HT rebuild project and i know myself well enough to realize that i will plan out the hushbox to death so if i want this done before my lungs give out, i need to start planning now.
i want to build a shaped one - not a extreme as the Italian monument to beauty posted here, but more like Kal's that follows the profile.
so... do i build it so that the case remains on the PJ, or designed so that the case is off.
case on advantages:
    - the PJ cooling flow was designed with the case on so i shouldn't mess with that
    - i won't have to find a place to store the damn case Smile
case off advantages:
    - smaller hush box possible
    - better final look as i can fit the hushbox closer to the PJ shape
    - easier to work on the PJ as i won't have to open the hushbox and then remove the case
i'm really leaning toward case off, but don't want to mess with the cooling because even though i will have a fan sucking air out, the PJ was obviously designed to be pulling air in from the sides/front and a hush box will just be sucking in at the front and exhausting out the back.
perhaps sucking in past the lens and over the boards is better than in the sides. does anyone know?
thanks
Posted: Wed Nov 29, 2006 8:51 pm    Post subject:
You've got an XG right?
When I had one for few months I was going to hushbox it too and looked at the fans closely to see how the airflow was designed to work.
My conclusion was that airflow's not really designed in an XG. The engineers simply popped in a bunch of fans where they thought they'd be needed. Lotsa turbulence.
I'd run it with the cover off - it'll probably cool better.
zaphod
Posted: Wed Nov 29, 2006 9:53 pm    Post subject:
yep
[quote=kal]My conclusion was that airflow's not really designed in an XG. The engineers simply popped in a bunch of fans where they thought they'd be needed. Lotsa turbulence.
Kal[/quote]
thanks. i keep meaning to take some light paper and seeing which vents suck and which blow, but it sounds like you already did it.
"popped in a bunch of fans" brrrrr - design by luck...
Maurizio Prandi
Posted: Sun Dec 03, 2006 2:34 pm    Post subject:
I agree with Kal.
I don't think PJ manufacturers design the flow path based on fluid dynamic analysis.
Furthermore, with all electronic components, wires, cables, have you any idea of the turbulence inside?
If you have any doubts place a couple of temperature probes with digital display near the potentially "hot" components and monitor them.
Furthermore I don't even think engineers design the cooling system considering whether the PJ is floor mounted or ceiling mounted.
The flow of the heat changes in those 2 cases.
You also have to consider that in case you can't set-up the PJ with your remote (since some functions would be accessible directly on the PJ) you would need to provide access to the PJ keyboard.
On the plus side you can choose larger fans or a more powerful cooling system that would extend the life of your electronics.
Just my €0,02 Mr. Green
Maurizio
"A gentleman is one who never hurts anyone's feelings unintentionally." O. Wilde
Posted: Sun Dec 03, 2006 2:48 pm    Post subject:
I did some temperature measurements awhile back with my BG 1209s and with the top fiberglass cover of it ran a full 20 degrees cooler .
Posted: Mon Dec 04, 2006 1:17 am    Post subject:
I'm surprised at that since with the Barco 808/1208/1209 series, the fiberglass case doesn't do much other than make the projector look nice. There's a whole other aluninum case underneath it!
Z-Photo
Posted: Tue Dec 19, 2006 4:19 pm    Post subject:
One thing on the 120* series - if you ceiling mount the PJ it is better to reverse the fan located over the tubes - so that you are blowing cool air up and not trying to force hot air down..
Engineer by Day
Photographer by Night
My Portfolio
Person99
Posted: Tue Dec 19, 2006 4:24 pm    Post subject:
Hey Pete, have you tested this to see if the convergence tray is actually cooler that way? Would be easy to do just be monitoring the temp of the heatsink on the convergence output board. Cool idea though. May suggest that to some 120x owners.
Z-Photo
Posted: Tue Dec 19, 2006 4:26 pm    Post subject:
Not by measurement - mine runs stone cold anyway. Recapping had a good bit to do with that (new 105c caps run a lot cooler)
Engineer by Day
My Portfolio
zaphod
Posted: Tue Dec 19, 2006 5:10 pm    Post subject:
Maurizio Prandi wrote:
I agree with Kal.
between the time of year, getting the flu and focussing on the "room" part of this HT reno i haven't had any time to look at the hush box. sigh.
but i will design it to fit without the cover on the PJ. thanks for all the input
