Romberth
| Posted: Sat Dec 03, 2011 9:32 am Post subject: Usable 1209 parts in a 1209s ? |
Hello.
I am parting out a 1209 and still proudly own two 1209s.
What cards from a 1209 can be used in a 1209S?
I am sure this has been discussed before but I can't find it...
Thx !
barclay66
| Posted: Sat Dec 03, 2011 10:14 am Post subject: |
You will have to compare the Part Numbers of the Boards (R.....). Take a look at this list: http://www.curtpalme.com/docs/Barco_Graphics_cross_reference.xls
Although the column for the 1209s is almost empty, You can compare Your parts against the list...
Regards,
barclay66
Romberth
| Posted: Sat Dec 03, 2011 5:38 pm Post subject: |
Thx a lot Barclay66, I'll check.
barclay66
| Posted: Sat Dec 03, 2011 9:42 pm Post subject: |
If You can't figure it out I can make a list of 1209s Part numbers from the service manual I have...
Regards,
barclay66
barclay66
| Posted: Mon Dec 05, 2011 8:13 am Post subject: |
From Romberth's tube sell thread:
| Romberth wrote: | | I Looked at the xls you showed me and i see only 3 cross references (colors). I thought that at least 3 or 4 cards could be swap-able. |
There are more interchangeable boards! It's just that the XLS file is not complete for the BG 1209s.
I've added them from the service manual. The boards/components unique to the 1209s are bold...
Regards,
barclay66
| Description: |
 Download |
| Filename: |
Barco_Graphics_1209.pdf |
| Filesize: |
44.51 KB |
| Downloaded: |
681 Time(s) |
Romberth
| Posted: Mon Dec 05, 2011 1:17 pm Post subject: |
This is just great ! Thx !
| Posted: Mon Dec 05, 2011 4:55 pm Post subject: |
The quad and EHT might also work if you use the matched set. Quads are getting scarce....
