XG110 ALIGNMENT
edavi394
Posted: Tue Nov 22, 2011 9:20 pm    Post subject: XG110 ALIGNMENT
Hi, I am going through my setup for my projector again. there are a lot of things i have forgotten. one issue I am having is lining up the test pattern for the static alignment. everything is zeroed out, and i have the horizontal aligned but the blue grid is just enough above the green that I max the blue vertical setting before it aligns with the green and the red is off the same the other way. I was thinking there was a manual adjustment somewhere but can't seem to find it.
edavi394
Posted: Tue Nov 22, 2011 10:53 pm    Post subject:
also I am interested in using the pc control software to do the adjustments. I have a laptop with a 9 pin serial port on it but I do not know if it is a RS232c or a RS422 how do i find out and also it says to use it as rs-422 contact manufacture.... any ideas? thanks
benareeno
Posted: Wed Nov 23, 2011 4:31 am    Post subject:
you need to align the guns in the reference adjust mode...have you done this?
Or...conversely, perhaps you need to move the green to it's max upwards.
edavi394
Posted: Wed Nov 23, 2011 5:20 am    Post subject:
not sure what you mean by "reference adjust mode" I have went to align and used static to try to move the grid but it reaches is max before they align. they are dead on left and right set to 0 but off vertically... oh and I got my control cable made and it works great with my laptop. Smile
Posted: Wed Nov 23, 2011 5:31 am    Post subject:
Youre meant to use static for very minor tweaking, not for full on alignments!!
edavi394
Posted: Wed Nov 23, 2011 5:35 am    Post subject:
yeah i thought so that's why I was not wanting to try to adjust it there but it has be several years since i last set this thing up. at one time i probably could have just about quoted the manual from memory and gotten about 3/4 through the set up process in my sleep... I have been reading the manual again but it is a lot to read.
benareeno
Posted: Wed Nov 23, 2011 6:57 am    Post subject:
go to service menu...password 3151, go to reference adjust and raster centering. THere should be plenty of range to get them back to normal.
benareeno
I might be wrong on the password...just do a search and you'll find it.
Posted: Wed Nov 23, 2011 2:56 pm    Post subject:
Ben's got it right, that's it.
edavi394
Posted: Wed Nov 23, 2011 4:40 pm    Post subject:
Thanks I will give that a try... i guess what I am doing now is just a temp theater. my wife wanted something set up before her family came to our place for Christmas. I think I have decided to do a stack with a pair of xg's and use a rear projection screen. I will probably start on this after the first of the year....
edavi394
Posted: Thu Nov 24, 2011 1:46 am    Post subject:
Well I tried to center the raster but I can not move the colors independently from each other. This does nothing for me. Because to matter how I move it the blue stats the same height above the green and the red stays the same below it. How do I move them separately?
benareeno
Posted: Thu Nov 24, 2011 1:53 am    Post subject:
are you going where I told you to go to do these adjustments? ref adjust..?
Posted: Thu Nov 24, 2011 2:28 am    Post subject:
Cant you adjust the tilt of the green up and down on an XG or is that only the LC??
edavi394
Posted: Thu Nov 24, 2011 6:33 am    Post subject:
ctrl + adjust right? not sure about the tilt...
edavi394
Posted: Sat Nov 26, 2011 9:03 pm    Post subject:
here is a pic with everything set to 0. the horizontal is not bad but you swill see the vertical is not close. it will get close using static but still more then a line width away.
MikeEby
Posted: Sat Nov 26, 2011 9:35 pm    Post subject:
Use the reference adjustment raster centering to get it closer. You won't have as much drift if you don't push the user controls as hard.
edavi394
Posted: Sat Nov 26, 2011 9:46 pm    Post subject:
thx I have tried that but I can not move each color independently. So all I do is move that image around the screen. There is no way to get the lines closer..
MikeEby
Posted: Sun Nov 27, 2011 1:00 am    Post subject:
If you go in it using the 3151 passcode then it will allow separate adjustment...At least mine does....Going in with a normal passcode they all move together.
edavi394
Posted: Sun Nov 27, 2011 1:31 am    Post subject:
Ahh! I see thanks. I almost tried that but my pass code let me in and when i entered it wrong on accident it would not let me into the menu.... thanks alot I will try this and post my results.
