Marquee 9500LC LVPS Mod: Help needed!
barclay66
Posted: Tue Nov 22, 2011 6:11 pm    Post subject: Marquee 9500LC LVPS Mod: Help needed!
After having collected most of the parts for my new PJ, I now have started working on the different boards. This includes:
- Replacing most of the electrolytic capacitors (more than 140, I'm using Panasonic FC, FM & Nichicon PW)
- Measuring capacitance & ESR of the remining caps
- Checking for essential Mods (Filament, anamorphic, other Tech Bulletin stuff)
- Applying additional filtering on FCM, VDM, CVA etc.
- Cleaning up the chassis
- Replacing the fans
It's the last part where I need some help.
Obviously the fan manufacturers put most of their development effort into the 12V segment. It therefore is much easier to find affordable 12V fans which produce much less noise without having to live with less airflow. And this is why I would like to modify the LVPS section which produces the 24V for the stock fans.
Now and then parts of the LVPS schematics show up and I'm confident that there is a complete one out there somewhere (Scott???, Mike Parker???). So, if anyone has access to this schematic I would be very grateful if this person could send me a copy of at least the 24V section.
I already have thought of alternative solutions (additional voltage regulator, adding one fan and connecting three groups of each two fans in series etc.), but modifying the supply seems the cleanest solution to me. Of course I'm aware that the mod will make the LVPS and chassis unique and no longer interchangeable with stock parts and if anyone has a better idea I would be glad to hear about it...
Thank You for reading!
Regards,
barclay66
Posted: Tue Nov 22, 2011 7:06 pm    Post subject:
Hi Barclay, just use the 12 volt regulator add on. it works great and use those Enermax Enobal bearing fans. I have had no issues.
Or you can use the rubber mounts for the existing fans and add a 22 ohm resistor in line to slow it down to a point where its safe.
Oh and here is Jea Hong Lees mods i put into a word document.
https://files.me.com/nashou.66/8o70kq
Posted: Tue Nov 22, 2011 7:08 pm    Post subject:
Oh and leave the existing belly fans and just use the rubber mounts or use some acoustic 1/8 inch thick foam and silicone them down with a few drops.
Posted: Tue Nov 22, 2011 7:09 pm    Post subject:
I am not an E'home guru, but had some fun on two of them... As far as I know there is no accesible schematics from the LVPS (neither from HVPS) since they wasn't manufactured by E'home, as I know the power supplies were handled as replacement parts, they are "not repairable"
Posted: Tue Nov 22, 2011 8:52 pm    Post subject:
Edit: never mind, I misread your question. Still a little frazzled from something else. Laughing
barclay66
Posted: Tue Nov 22, 2011 9:27 pm    Post subject:
Hello Athanasios,
Thank You very much for the document! Very good read!
I think it might make sense to go with the voltage regulator solution. I will take a look at the LVPS board if I can find a nice place where there is enough space for it and where it doesn't interfere with the rest of the LVPS.
Rubber mounts were already on my list. I just wanted to get the electronical part straightened out before moving to mechanics. Wink
I've made a complete list of all replaced electrolytic caps (including mechanical dimensions for each). Interested?
Regards,
barclay66
Posted: Tue Nov 22, 2011 10:07 pm    Post subject:
Here is my LVPS list I call it BlackGates to heaven . Wink
barclay66
Posted: Tue Nov 22, 2011 10:38 pm    Post subject:
Umm, which list?
Posted: Tue Nov 22, 2011 10:45 pm    Post subject:
Umm, which list?
oops!
https://files.me.com/nashou.66/ulnj4i
barclay66
Posted: Tue Nov 22, 2011 11:27 pm    Post subject:
That's impressive! See attached mine. It's for all boards that I've been working on until now. I have two Deflection Processor boards here, so it's listed twice...
Regards,
barclay66
Edit: Replaced file with a PDF Version because I was told the XLS showed weird numbers where the mech. dimension values should be
Replaced caps.pdf
 Filename:  Replaced caps.pdf
 Filesize:  308.57 KB
 Downloaded:  576 Time(s)
Posted: Wed Nov 23, 2011 12:21 am    Post subject:
Nice list, I like how you marked the PCB cap locations.
I think I bought the remaining inventory of most of those BlackGate caps from parts connection and Sonicraft.
I only did one LVPS so far and did not do the Jea Hong lea mods to the Ultras yet. But I will.
Posted: Wed Nov 23, 2011 12:34 am    Post subject:
Hello
HOLD IT! The fans are not noisy due to fan speed, they are noisy due to cheap bearings that degrade over time. Leave the circuits alone and drop in two Papst 3414NGLs for the LVPS, you will have nothing to complain about. The belly fans are not a source of noise, leave as is.
barclay66
Posted: Wed Nov 23, 2011 10:41 pm    Post subject:
Good point. I will look into this...
Just another question: Is it safe to operate the LVPS by its own (signals for switching it on applied) or does it need some minimum load for proper operation? I would like to check the voltages and scope the outputs...
Regards,
barclay66
Posted: Wed Nov 23, 2011 11:23 pm    Post subject:
JUst read them from the motherboard. It does need a load and you wont damage the LVPS if you screw up Like iddi when I got my first Marquee.
And I know Tim is cautious but the 12 volt Enobal bearing fans work fine .
The belly fans are more of a concern, those should be left alone.
barclay66
Posted: Fri Nov 25, 2011 1:05 pm    Post subject:
Update:
I've decided against the LVPS modification (24V -> 12V) but also against adding a voltage regulator -and- will be using 12V fans. I will go the same route as HK-Steve (see: http://www.avsforum.com/avs-vb/showthread.php?t=829082) and add a fourth belly fan. By this I can connect them in series (two groups for the belly section and one for the LVPS). I had looked up prices for Papst fans (4414FL & 3414NL) and they really cost a fortune over here. The market for silent and performant 12V fans is so much broader that I'm confident I will find good ones.
Thank You for sharing Your opinions!
Regards,
barclay66
Posted: Fri Nov 25, 2011 1:18 pm    Post subject:
Papst is a German brand, isn't it? That's interesting...
barclay66
Posted: Fri Nov 25, 2011 2:15 pm    Post subject:
You're correct. There is a saying in Germany: The shoemaker's kids will always wear the worst shoes. Seems to apply here too... Wink
Regards,
barclay66
