Jeremy112
| Posted: Thu Nov 10, 2011 6:37 pm Post subject: Sony 1272Q - Horizontal Gibberish - need some assistance |
Hey guys,
Im hanging my friends 1272Q today and I need to know the exact thread and diameter of the holes in the projector for the bolts.
I'm almost ready to get it hung but I need to get the hardware for it first. so any help is appreciated!
Jeremy112
| Posted: Thu Nov 10, 2011 9:46 pm Post subject: |
Nevermind guys, found a DIY guide online with the correct threading for the bolts! let the hanging begin!
| Posted: Thu Nov 10, 2011 9:50 pm Post subject: |
When mounting your 1272 I suggest putting it on a firm surface. Dress yourself in a kilt ( these 1272's can get spooked by the sound of a zipper ). Sneak up from behind ( keeping the lens caps on can aid you here )....
A block and tackle can help as well to get you or your 1272 into just the right position.
Jeremy112
| Posted: Fri Nov 11, 2011 12:06 am Post subject: |
Lmao AR, I hear ya there, heres a couple pics, One shows it hung, the other shows the image on the screen (please forgive the photo quality of my friends crappy phone camera)
The problem I am having is in picture 2, the horizontal image is all gibberish like, the photo explains it better. Anyone have a theory?
RayN999
Joined: 25 May 2010 Posts: 207 Location: Minneapolis, MN
TV/Projector: Sony VPL-VW60 and Toshiba 65H84 CRT RPTV
| Posted: Fri Nov 11, 2011 12:10 am Post subject: |
Looks like he took the kilt approach.... In other words, it's f*cked!
_________________ Ray Nelson
N9QBV
Jeremy112
| Posted: Fri Nov 11, 2011 12:15 am Post subject: |
as Mr. Scott on star trek would say "aye Captain, I'm givin it all shes got!"
RayN999
| Posted: Fri Nov 11, 2011 12:20 am Post subject: |
In a kilt, no less.... (Knowing Jeremy112 personally, that's a visual image I'd rather NOT have in my head....)
N9QBV
Jeremy112
| Posted: Fri Nov 11, 2011 12:26 am Post subject: |
| RayN999 wrote: | | In a kilt, no less.... (Knowing Jeremy112 personally, that's a visual image I'd rather NOT have in my head....) |
I'd actually like to see you in a kilt sometime ray, pop a pic for a good laugh
Jeremy112
| Posted: Sun Nov 13, 2011 6:16 pm Post subject: |
Bump, anyone have any ideas? I know this set is an antique but if it can last a few more years that would be great.
Would a capacitor not being soldered on one lead, on the horizontal deflection board be a cause for this?
RayN999
| Posted: Sun Nov 13, 2011 7:21 pm Post subject: |
J, try to resolder that capacitor first. I would bet that it's in the horiz timing or horiz flyback circuit & is the source of that issue. If I'm way off base, someone else might have other ideas, but I think that'll fix it right up.
N9QBV
Jeremy112
| Posted: Sun Nov 13, 2011 11:11 pm Post subject: |
| RayN999 wrote: | | J, try to resolder that capacitor first. I would bet that it's in the horiz timing or horiz flyback circuit & is the source of that issue. If I'm way off base, someone else might have other ideas, but I think that'll fix it right up. |
I sure hope so, it wa sworking before we flipped it so it better be nothing serious, because I am NOT helping to take it back down
Matrix
Joined: 06 Sep 2006 Posts: 123 Location: Indianapolis, IN
| Posted: Mon Nov 14, 2011 1:22 am Post subject: |
| Jeremy112 wrote: | | RayN999 wrote: | | J, try to resolder that capacitor first. I would bet that it's in the horiz timing or horiz flyback circuit & is the source of that issue. If I'm way off base, someone else might have other ideas, but I think that'll fix it right up. |
I sure hope so, it wa sworking before we flipped it so it better be nothing serious, because I am NOT helping to take it back down  |
You flipped this PJ from floor to ceiling and it worked before the swap? Re check the plugs you switched for the tube/set inversion.
_________________ Dennis in Indy
jarseneau
| Posted: Thu Nov 17, 2011 7:19 pm Post subject: |
Jeremy, did you have any luck with the jitter? I had this once on a 1272 and using contact cleaner on the connectors going to the yokes appeared to fix it. Could be that or a cold solder joint on the board.
_________________ Jerry
Jeremy112
| Posted: Mon Nov 21, 2011 10:34 pm Post subject: |
Hey Jerry,
I forgot to post my status on here! I did indeed fix the issue, it was a smalll 50v 33uf capacitor on the horizontal deflection board, it was broke loose from the contacts, all is well now, and the projector is working better than ever!
I do have to ask though, I have a 16v 1000uf capacitor that I have replaced twice now, it keeps doming and the capacitors I'm using for it I have been using in other electronics and I have not noticed any doming... could there be some other issue in the circuit that is causing this?
| Posted: Mon Nov 21, 2011 11:53 pm Post subject: |
Well I would hope that your using a good quality cap.. You can increase the voltage of the cap if you have the room and see it that stops it. How quickly is it failing?
As far as to whether something else could cause it I would need a lot more info on what you have to answer that question.
Jeremy112
| Posted: Tue Nov 22, 2011 12:19 am Post subject: |
the capacitor honestly seems to be mildly buldged after only 3 hours of use since replaced... The capacitor brand is Rubycon, which I thought would be a better brand than most ebay brands... like I said so far the rubycons of that exact same value that I have, have not domed or gone bad in any other electronics that I have here at the moment... so I don't know what the deal is....
I was also thinking of trying a larger capacitor to see if that would solve the issue. We will see if it comes to that I suppose. And as far as what I have, I don't quite understand the question.
| Posted: Tue Nov 22, 2011 12:37 am Post subject: |
| Jeremy112 wrote: | the capacitor honestly seems to be mildly buldged after only 3 hours of use since replaced... The capacitor brand is Rubycon, which I thought would be a better brand than most ebay brands... like I said so far the rubycons of that exact same value that I have, have not domed or gone bad in any other electronics that I have here at the moment... so I don't know what the deal is....
I was also thinking of trying a larger capacitor to see if that would solve the issue. We will see if it comes to that I suppose. And as far as what I have, I don't quite understand the question.  |
I would question any capacitor not purchased from a very reliable source.
Because the same caps seem ok in other devices does not mean they are ok. There are many variables that would apply as a comparison.
Are far as me saying what you have, I meant I would need to know what the circuit design is, the operating voltage and such. This would be to determine if something else could be causing the problem. It's to hard to just say it could be caused by something else.
In layman terms.... it could be a bad cap, to low voltage rating of the cap or something causing to much stress on the cap.....
And I'm sure this didn't help answer your question, lol.
