need to change my bulp in my projector.need some help
esc_cos
Posted: Thu Oct 06, 2011 9:24 pm    Post subject: need to change my bulp in my projector.need some help
hello
i have an epson tw4400 projetor
im verry sure my bulp is broken.
suddenly i heard a noice,and then the light from the projetor stopped. and the waringlight for the lamp started to flacsh on the
projetor
i looked in the manual of how to change it.
it sead something like this:
Insert the supplied screwdriver
of the replacement lamp into
the lamp cover opening switch,
then remove the lamp cover
and on the pix i could see some kind of spesial tool? that i need to use to get the of the lamp cover ,to get inn and
change the bulp.
and the place where to put in this tool was on the backside of the projector. where the connectons is mounted on.
but should that tool come with the projector paccage??
beacouse there was not that cknd of tool on mine.
so i dont have it.
realy need help from you experts
thanks a billion
esc_cos
Posted: Tue Oct 11, 2011 9:01 pm    Post subject:
but how now open the lamp cover that i had problems with
have also taken out the lamp housing,and taken out the bulp itselves
so thats okey.
but one question regarding the old broken lamp.
the lamp is totaly broken,damaged. and all the glass components on the bulp is broken ,damaged. and the glassparts of the bulp
come
through, out of the lamphouse. when i took it apart
have you every heard about enything like that?
i hav shanged a few lamps and never seen enything like it
Posted: Tue Oct 11, 2011 9:39 pm    Post subject:
Yes, that's very common with digital bulbs.
esc_cos
Posted: Tue Oct 11, 2011 10:39 pm    Post subject:
thanks
good to know. thought meybe it could be something wrong with the projector.
one more thing.
im trying to find a new lamp.
but there are a big price difference betvean original epson genuin bulps, and after marked, copied ones.
it seas 100 % compatible on the aftermarked ones,but still?
what should i bay?
enyone used the aftermaked ones ?
ore how do you experts do it?
thanks agein mates
Posted: Wed Oct 12, 2011 4:35 pm    Post subject:
I've bought one aftermarket bulb off eBay with no problems, but I don't really work on them, so I can't say that everyone has had good success with the ones on eBay.
esc_cos
Posted: Wed Oct 12, 2011 6:06 pm    Post subject:
thanks
do you ore enyone know if there could be a bit wors imgage from the cheap lamp`?
thats the only thing im worried about realy
concer
Posted: Mon Nov 14, 2011 6:35 am    Post subject:
Work, and there are two girls intend to go back together, then, a girl said to another girl: how can you not go, so you do the frog?oo
(NOTE FROM THE MODERATORS: I was going to delete this but it's just funny)
Gannon
Posted: Fri May 11, 2012 5:11 pm    Post subject:
I'm bumping this because YES a bad bulb can make the image worse, or fail prematurely...wasting your money.
Who's got reliable bulb sources?! I've a friend with an Epsom who needs a bulb, too.
I want them to avoid getting scammed on eBay.
Cheers,
John
Detroit
gadfly and rogue philosopher
Posted: Fri May 11, 2012 5:20 pm    Post subject:
I've only bought two on eBay, but both worked fine. I have heard horror stories though.
Just stay away from the 'bulps'.
Posted: Fri May 11, 2012 7:20 pm    Post subject:
John,
There are some guys buying aftermarket bulbs over on AVS. I don't remember where they are getting them, but you should be able to find it. I thought Epson bulbs were $200 a pop.
