Sony D50Htu adjustment
Rustyscout
Posted: Sun Oct 02, 2011 8:19 pm    Post subject: Sony D50Htu adjustment
I recently took my d50 out of storage and looking to get it set up. I posted this also on AVS but have had no response. (I know shocker). I had no problems setting up the green and red CRT's but the problem is with the blue. Maybe I am still not setting it up correctly but the test patterns are not on the tube face correct. Meaning the test patterns are missing the last portion on the left. I put up a hatch pattern and it is missing the last line on the left. I am sure it is just a simple adjustment. I do have the remote and manuals etc that originally came with the unit many years ago. What do I need to adjust? Clarification by looking at the crt faces with the leses on and sunglasses on I can see the pattern is missing all the way to the left and there is just to much room on the pattern to the right. Any help would be appreciated.
Rustyscout
Posted: Sun Oct 02, 2011 8:38 pm    Post subject:
Question, Do I just re-adjust the centering of the blue CRT and then manually re-adjust the tube after loosening the four screws? (on the top) Hope this makes sense.
Posted: Sun Oct 02, 2011 8:49 pm    Post subject:
Check the blanking for that section of the image. You may have to much.
Rustyscout
Posted: Sun Oct 02, 2011 9:05 pm    Post subject:
will do, thanks
