| Posted: Mon Sep 26, 2011 9:59 pm Post subject: A little OT, USB ports |
It is for a home theater device so it's not to far off. IT's a audio adapter/decoder that get's it's power through a mini usb connector. The other end of the connector cable is a full size usb connector that plugs into a xbox, ps3 or a pc for power. The question is, are all usb ports created equal? I want to use/connect this to my LG flat screen. The LG does have a full size usb port. Will that port have the 5 vdc that I need for the device? If that doesn't work, I'll have to order a 5 vdc usb wall wart.
_________________ Chip
MikeEby
| Posted: Tue Sep 27, 2011 5:23 am Post subject: |
Try it and fry it
Go for a powered USB hub with a 2 amp power supply. I see those cheaper than the 'proper' USB wall warts sometimes.
Jeremy112
| Posted: Tue Sep 27, 2011 9:36 pm Post subject: |
Ive assembled some gadgets with USB connections and as far as I am aware most USB ports all have 5vdc. If they didn't keyboards wouldn't work
Like analog said, try it and see what happens
jask
| Posted: Wed Sep 28, 2011 7:12 am Post subject: |
If it is less than 500mA you should be fine.
| Posted: Wed Sep 28, 2011 10:24 am Post subject: |
The device is a Turtle Beach EarForce DSS. I just looked up the power supply specs and it lists 5 vdc @120mA.
Aftet looking at the specs for various versions of the full size USB connector, they all show the same pin-out (4 pin)
with the outer two pins being power and the inner two being data.
I don't know if construction for these is all the same but a quick glance of the socket tells me you DON'T want to attempt probing for power as the surround for the socket is metal. I doubt you could test it without shorting to the case.
So I gues it will be "turn and burn" or "burn and return" or something like that
