Gerbrand
| Posted: Sat Sep 24, 2011 8:05 pm Post subject: Moomecard.com down? |
Just wanted to check the latest on Moome and found their site to be down. Has it been relocated or is this just temporary.
Gerbrand
_________________ BG1209s (color filtered,new LUGs!), 13000h
Bat cave
cinema mad
| Posted: Sun Sep 25, 2011 8:36 am Post subject: |
I noticed the same thing, Moomecard.com is coming up as Blocked in the Google search list
So I took it as either my Browser/google or Service provider is blocking Moomes site or it is indeed down ?
Try this link
http://moomecrtpj.blogspot.com/
Ron W
| Posted: Wed Sep 28, 2011 6:10 pm Post subject: |
| cinema mad wrote: | I noticed the same thing, Moomecard.com is coming up as Blocked in the Google search list
Try this link
http://moomecrtpj.blogspot.com/ |
That is an older site. It has been several days now without a peep from anyone on the nature of the Moome website. I guess the logical question to ask is "are they out of business"?
| Posted: Wed Sep 28, 2011 7:10 pm Post subject: |
Try this link
The link seems to work fine for me...... Using Firefox
cinema mad
| Posted: Thu Sep 29, 2011 2:21 am Post subject: |
Ron I think its safe to assume Moome is "NOT" going out of business
I have no probs accessing Moomes BlogSpot link I posted above..
But for www.moomecard.com using google I get "Block all www.moomecard.com results" underneath the same listing ..
Perhaps Moomes site is being blocked due to the Laws introduced a while ago regarding HDFury/Moome external & similar products As Kal brought up A long while back when the above products where revoked from Curt Palme.com..
Ron W
| Posted: Thu Sep 29, 2011 4:06 pm Post subject: |
| cinema mad wrote: | Ron I think its safe to assume Moome is "NOT" going out of business
Perhaps Moomes site is being blocked due to the Laws introduced a while ago regarding HDFury/Moome external & similar products As Kal brought up A long while back when the above products where revoked from Curt Palme.com.. |
You may be right but here again, the blogspot you mentioned is an older page and Moome hasn't communicated on this forum for awhile. It is also interesting to note that even when you go to this blogspot, scroll down to the "Buy Now" column for the V3 Ext HD and click on it, the same "Not Found" issue comes up on the page. Perhaps Kal and/or the guys can finally clarify this situation,however, the reality is if one can't access their main site and hence, can't place an order , from where I sit then, they might as well be out of business.
cinema mad
| Posted: Fri Sep 30, 2011 4:09 am Post subject: |
For the time being i would think You can request product info & or order V3 Ext HD by contacting Moome directly through Email & simply asking him for A Paypal payment request to be sent to your paypal account..
Suffice to say The above method should be fine Untill we hear from Moome regarding his web site..
As im sure theres A reasonable explenation behind it & seeing how HDFury site can still be accessed..
Matrix
Joined: 06 Sep 2006 Posts: 123 Location: Indianapolis, IN
| Posted: Sun Nov 13, 2011 2:27 pm Post subject: |
As of Sunday, Nov. 13th 2011 all is well with Moome. He states via email to me, Sony cards are available and it is business as usual, no problems filling card orders.
Moome also commented his new web site is still under construction but unavailable at this time. Stay tuned.
_________________ Dennis in Indy
thewolfman
| Posted: Fri Nov 25, 2011 12:00 pm Post subject: |
| Matrix wrote: | As of Sunday, Nov. 13th 2011 all is well with Moome. He states via email to me, Sony cards are available and it is business as usual, no problems filling card orders.
Moome also commented his new web site is still under construction but unavailable at this time. Stay tuned.  |
Hi there!
I'm a owner of 9500LC with a moome V1 and like to make it 1080P/72/75hz complient in some cheap way. If I had the money I would buy the Radience x+ to make the 72/75hz 1080P possible but that's to expensive. If I could I would buy a better computer with 3D grafic card output with 72/75hz. But then I might need a VIM V3 after all to make it HDCP complient as I gather grafic cards does not..Not sure on this either.
Do you know when moome EXT FullHD V3 will be ready for order? I haven't got around to have my machine brought to my place yet so no chance of testing the V1 for 72/75hz 1080P but think it does not support that refresh rate. Even if it did I would have it changed for a better picture over all.
I 'm also very confused about the VIM-Full Hd Moome V3.. is it 3D and 1.4 HDMI or not? And most important 72/75 hz at 1080P?
I also like to have 3D but not sure if VIM-Full HD V3 has that feature. If you have a chance have a look at this site on page 3.. It says nothing about 3D and DTV support for only 50/60hz at 1080P. What's DTV in this case? On page 5 it says full support for 1080P 72/75hz on HDTV.. I cant tell the difference, as I always think of RGB usually on my older non FULL HD CRT I had before.
http://www.curtpalme.com/docs/vim_fullhd_v30.pdf
And when i read about the VIM-Full HD on this site...below the EXT Full HD moome.. http://moomecrtpj.blogspot.com/ ... it's 1.3 and 1.4 HDMI all of a sudden.. + "Stereoscopic 3D" Is it same as the EXT 3D moome..or what?
A little of a newbi, but not a complete idiot on thes things, just confused. Hope you or someone else can set me straight on what's right on moome 3D and 72/75hz.
Kind regards
Ulf Karlsson
Sweden
| Posted: Fri Nov 25, 2011 1:55 pm Post subject: |
Wolfman, start a new thread, this one will get lost here.
My Moome card should be here any day, I ordered about 10 days ago, so I'll post when it shows. 2 to 2 1/2 weeks seems about normal for delivery to Canada based on past orders.
thewolfman
| Posted: Fri Nov 25, 2011 2:01 pm Post subject: |
| Curt Palme wrote: | Wolfman, start a new thread, this one will get lost here.
My Moome card should be here any day, I ordered about 10 days ago, so I'll post when it shows. 2 to 2 1/2 weeks seems about normal for delivery to Canada based on past orders. |
Okej, thanks for the reply Curt, I will start over with a new thread then. I gather you have orderd a bunch of 3D moome from Canada, and if so I will buy one for sure.
Ulf
karachifoods
| Posted: Fri Dec 30, 2011 6:52 am Post subject: hello |
| cinema mad wrote: | For the time being i would think You can request product info & or order V3 Ext HD by contacting Moome directly through Email & simply asking him for A Paypal payment request to be sent to your paypal account..
As im sure theres A reasonable explenation behind it & seeing how HDFury site can still be accessed.. |
this is the perfect info thanks for sharing.
_________________ pulao recipes
barclay66
| Posted: Wed Jan 04, 2012 9:46 pm Post subject: |
THe site is down again..
jask
| Posted: Thu Jan 05, 2012 5:29 am Post subject: |
back up..
