Ron W
| Posted: Sat Aug 13, 2011 6:42 pm Post subject: Re: Sony FullHD v1 now gives Error 10 on HDMI1 |
| Chuck Anstey wrote: | I was doing some adjusting on my Sony G70 with the AVS-HD Blu-ray disc and the picture just went away and there was no longer a signal on Input-B. After checking everything out and switching the HDMI cable directly to the player, I saw the G70 giving Error 10 - Bad signal. The FullHD card showed a solid green light that it detected the HDMI with no issues. I tried reseating the card but that didn't fix it. I switched the cable to HDMI2 and it is working again but I worry it is a matter of time before that one goes out too since I don't know why HDMI1 stopped working properly.
Has anyone had this issue before? |
I am not totally sure about the function of the FP cards but assuming they are identical to the Ext Full HD units, the problem you may be starting to encounter is the gradual failure of the "auto-sensing" function which has been fairly common in the V2 units. I went through two V2 units myself, BOTH of which eventually failed in a similar manner and after several weeks of use would no longer lock on to the signal or at best, I would start to experience regular video dropouts. Since you have started to have the problem, rest assured the second input will more than likely eventually fail as well. These would have been better if they were designed like the Fury 3 in which, right from the beginning, you could have the option of disengaging the "auto sensing" function and connect one or the other input manually.
