Samsung HLS5687WX XAA flashing lights and click
romero.video
Posted: Fri Aug 12, 2011 4:35 pm    Post subject: Samsung HLS5687WX XAA flashing lights and click
This 56" dlp is mint. Great setup. When plugged in, i get the green flashing light a few times with a sound like an alarm, then a red flashing light with a different sounding alarm. You can also here a relay click as if it's starting up. Again as mentioned in my other 56", it's not the bulb but other than that, I'm not sure what to look at first. Could the dmd boards be out on these or could it be something else?
TheVerge
Posted: Fri Aug 12, 2011 7:17 pm    Post subject:
You should probably put both of these in the same thread. Also know you are on a CRT board, probably get better answers in the rptv section of avs.
romero.video
Posted: Fri Aug 12, 2011 8:21 pm    Post subject:
Well it does say DLP which is what these are. I separated them so i can focus on one at a time rather than get confused and mixed up. I really want to begin work on this one first. I posted the other as i was able to get to it easier at the time.
