peter_jam
| Posted: Fri Aug 05, 2011 1:43 pm Post subject: Calibrating white level with disney WOW |
Hello everyone,
Yesterday I got my copy of disney's world of wonder calibration blu ray. Since it was already late, I only had time to glance through the basic video calibration, and I plan to perform a full calibration later today. However, I noticed something when adjusting the white level. On the screen, you get a display with three bars on the left, a big white square on the right, and another three bars on the right. The instructions say that you should increase your white level until the center square becomes a white resembling clouds or a new white shirt, and until you only see the first bar on the right, and the last 2 become the same level of white. My problem is that I turned the white level all the way up (I think it's the contrast control right? I can't remember right now but I'm sure I didn't get that wrong since both the menu and the booklet explain it clearly), but I can still clearly see the 3 bars on the right. Do you think this can be corrected once I perform the advance calibration setup? Also, when adjusting sharpness, all the edges from the calibration template seemed really defined with sharpness all the way down to zero, and I saw almost no difference when I turned it back up. Could this be because of the high resolution? Because I don't think that zero is an appropiate setting. Any help will be appreciated, I'm sorry if these seem like a silly questions, but I saved money for a long time so that I could buy and lcd tv and a blu ray player, so I'm trying to get the most of them. Thank you very much.
P.S. My TV is a Philips 40PFL5505D/F7, in case you needed to know.
