modelbeer
| Posted: Sun Jul 24, 2011 9:46 am Post subject: Barco Cine 7 powers up but no picture projected (led's on) |
Hi guys
Last night upon returning home I tried to watch a move on my Barco Cine 7. Well unit came online fine with cricket sounds and fans working, but there is no picture being projected. I locked at led's on top of the unit and this is what i have.
Power on with standby Led on. Pushing on button on remote and unit comes alive with:
Coinc Led - On Orange
Hold Down HD Led - Off
SF Led - On
Hold Down EHT Led - Off
Standby Led - Off
The rest of the green Led's are On where HTHD green Led is not as bright as the rest.
I am relatively new to this unit and have no experience using it. From what i get from the manual is that you have to select a source via remote and then picture will come up on the wall. No I have it connected to dvd player via s-video and to blue ray player via RBG connection.
Also looking down the lenses it seems that there is a glow but I have no reference point to say it for sure..
Can some one shed some light on what could be the problem.
(Also, does the unit still have to project it's setting menu, even if there is nothing connected to it?)
Any help will be appreciated.
Thank you
| Posted: Sun Jul 24, 2011 1:32 pm Post subject: |
The SF light means 'scan fail', so your H or V deflection is not working. There are two LEDs on the center deflection board, is the top or the middle one lit? Chances are the deflection board is bad, I have spares if you need it.
bvgoor
Joined: 04 May 2018 Posts: 14 Location: United Kingdom
| Posted: Mon Nov 18, 2019 5:26 pm Post subject: |
Hello I know this is an old listing but I have exactly the same issue with a Cine 7
Looking at the led on the board mentioned by Curt it’s the top led which is red
Does that give a clue?
Bas
| Posted: Mon Nov 18, 2019 6:00 pm Post subject: |
What do you mean by the 'top' LED? There is a row of LED lights over/under the green lens. Are the red ones off and all the green ones on?
bvgoor
| Posted: Mon Nov 18, 2019 7:43 pm Post subject: |
Wow, thanks for the quick reply !!
Top led on the central deflection board, this is as I have the projector on the workbench and the chassis open
I do have another Cine 7 (not complete) but have swapped the central deflection board and same result
Thx
Bas
| Posted: Mon Nov 18, 2019 8:09 pm Post subject: |
OK, that's the H output section of the deflection board:
http://www.curtpalme.com/Barco701_Layout5.shtm
If I remember correctly, the signal for the H deflection comes from the RGB input board. Since you already changed the deflection board, then it's likely that the RGB input board has gone bad. Do you have a spare?
bvgoor
| Posted: Mon Nov 18, 2019 8:14 pm Post subject: |
Yes I do have one so I’ll swap and report back, sometime tomorrow thx!
bvgoor
| Posted: Tue Nov 19, 2019 10:48 am Post subject: |
Swapped the complete tray to no effect same symptom
Used the original tray with only swapping the RGB input board to same effect
Anything else I can try?
Thx
Bas
| Posted: Tue Nov 19, 2019 5:36 pm Post subject: |
Hmmm. That's unexpected. So all the green LEDs over/under the green lens are on, and all the red ones are off?
bvgoor
| Posted: Tue Nov 19, 2019 5:52 pm Post subject: |
Yes 3 green lights on the rgb board
bvgoor
| Posted: Tue Nov 19, 2019 6:06 pm Post subject: |
If you mean the diagnostic leds we still have
SF Led - On
Standby Led - Off
And the hthd led is on but goes off after 10 seconds
There is neck glow in all three tubes
After the hthd led goes off the unit pulses or thicks every 10 sec (no change in leds)
| Posted: Tue Nov 19, 2019 10:42 pm Post subject: |
OK, this will be tough to troubleshoot without a tech that knows these units. We've swapped out the two most common problems, so now it's down to something unusual. You might try changing the power supply, but if not, it needs a tech with a 'scope to work on it.
bvgoor
| Posted: Tue Nov 19, 2019 10:47 pm Post subject: |
Curt,
Thanks for your help, is there a service manual ? Schematics available somewhere?
Bas
