SPL800
| Posted: Sun Jul 10, 2011 10:21 am Post subject: barco 1209s |
the remote control which attached to the pj is always with light on it even is stby mode is it normal?
Ile
| Posted: Sun Jul 10, 2011 10:46 am Post subject: |
Yes, it's same on all newer Barcos.
SPL800
| Posted: Sun Jul 10, 2011 11:38 am Post subject: |
hi Ile
Jesse S
| Posted: Tue Jul 12, 2011 12:47 am Post subject: |
regarding 1209s remotes, the attached one works but I have 2 wireless and neither can control the barco. Is there something I need to enable or change?
| Posted: Tue Jul 12, 2011 1:16 am Post subject: |
| Jesse S wrote: | | regarding 1209s remotes, the attached one works but I have 2 wireless and neither can control the barco. Is there something I need to enable or change? |
Looking at the front of the remote you will see what looks to be a place where a button is missing. You need to use a pencil or some object small enough to push this button and at the same time press "0" or "000" can't remember which.
| Posted: Tue Jul 12, 2011 1:40 am Post subject: |
The Barco remotes can control multiple projectors in a chain using addresses. The projector can be set to respond to a certain address only, using the dip switch's on the controller, what has been set does not matter as all projectors will respond to address 000. On the remote between the Adjust and Standby buttons is a recessed button you can press with a pen, press it and then press the 0 digit on the remote. The remote is now set to projector address 000 and the projector will now respond regardless to the actual address its set to. Alternately you can press the recessed button on the remote while aimed at the projector or screen and the projector will display its address (or bring up the Barco information screen from the menu to view the address), then proceed by pressing those numbers in sequence on the remote i.e. if the projector displays address 025 press 0 then 2 then 5 on the remote and it will be set to control a projector with that address, either way the remote will work again.
Jesse S
| Posted: Tue Jul 12, 2011 4:18 am Post subject: |
Thanks, I'll try that tomorrow.
Jesse S
| Posted: Thu Jul 14, 2011 9:10 pm Post subject: |
Both remotes worked after setting to 0, thanks.
