Converting a BD1209s to a BG1209s
Posted: Tue Jun 21, 2011 7:23 am    Post subject: Converting a BD1209s to a BG1209s
I have a Barco Data 1209s that needs new tubes but is there anything else I might want to replace before putting it on the ceiling ?
Fortunately I have a couple of sets of new color filtered c elements left and a very nice set of P19LPB03 tubes (9's with no visible phosphor wear) with very good emissions. Smile
The Barco Data 1209s specs:
http://www.curtpalme.com/docs/BarcoData1209s_Brochure.pdf
The Barco Graphics 1209s specs:
http://www.curtpalme.com/docs/BarcoGraphics1209s_Brochure.pdf
I do have a few spare BG1209s and BG1208s boards.....
Ile
Posted: Tue Jun 21, 2011 8:09 am    Post subject:
No high freq mode in data, so freq range is limited to 75kHz.
If you need higher scan rates, few board need to be chanced to make it G.
http://www.curtpalme.com/forum/viewtopic.php?p=130677
Decibel
Posted: Tue Jun 21, 2011 8:33 am    Post subject:
I compared the documents below (G1208s) and G1209s service manual.
The projectors are equal, except tubes and neckboards.
Now you can compare these documents with your Data 1209s
 Filesize:  72.18 KB
 Viewed:  2980 Time(s)
 Filesize:  121.06 KB
 Viewed:  2982 Time(s)
Domenico (Barco fan!)
Posted: Tue Jun 21, 2011 11:59 pm    Post subject:
Thanks for the reply's. So If I have this correct to convert a BD1209s to a BG1209s I need the following, all of which I have on hand.
Deflection switching board
controller
Horizontal board
Vertical board
The above boards all came from a BG1208s w/iris 3. Should the firmware work with the BD1209s or am I missing anything ?
Ile
Posted: Wed Jun 22, 2011 7:46 am    Post subject:
I understanded needed boards same way, but check first that datas mother board have needed connectors for graphics deflection switching board. According to this post there is also datas with three yoke connectors at mobo, maybe those were some pre-series units.
Not sure about BG1208s firmware, probably it works fine.
Posted: Wed Jun 22, 2011 8:14 am    Post subject:
Thanks Ile I forgot that thread...
