Digitali
| Posted: Fri May 27, 2011 6:59 pm Post subject: Barco Graphics 808s |
Hello dear Members...
First of all, sorry for my bad english......
I have a Barco Graphics 808s Date 1997...
I've buy it 2 years ago from a private seller. Till last week it works perfekt.
But now there no picture on the tubes.....
When i turn it on.... the blower are runnig and the LEDs of the tubes are green but there is no picture.
I don't know if it's the Quad, the EHT or something else....
The red LED on the EHT ist glowing red......
Here the PNs i could read.....
EHT R7617427
Quad R7722091
Yesterday i bought a Barco Data 808s which have a faillure too, in hope, that i can change some parts
to check out which part from my Graphics 808s are really damaged.
But the PNs from the Data 808s are differenz.
EHT R762716
Quad R762717
After i tryed to turn on the Data 808s which i bought yesterday i see that this projektor have the same faillure.
Blower are running, but there doesn't come any picture on the tubes.....
I don't know what to do..... which part parts are damaged ????
I need help.....
Greetings from germany
| Posted: Fri May 27, 2011 7:19 pm Post subject: |
Can you tell if you have high voltage to the tubes ? You should be able to hear the static charge build up.....
Digitali
| Posted: Fri May 27, 2011 7:28 pm Post subject: |
Oh...thats really difficult to say.......
Do you mean this sound when the Tubes are going warm up.....
The sound like electricity ??????
I'm not 100% sure...but i think the Data 808s makes this sound when i turn it on.
The electric bulbs on the ends of the tubes are glowing a little
How can i check it surer then only hearing ????
| Posted: Fri May 27, 2011 7:33 pm Post subject: |
You should hear that crackling noise if the high voltage section is working. Do you have any Red LED's lit on any of the boards ?
Digitali
| Posted: Fri May 27, 2011 7:37 pm Post subject: |
Only on the EHT Board the red LED is glowing......
On all the other boards the LEDs are green glowing
| Posted: Fri May 27, 2011 7:44 pm Post subject: |
You have a bad HV quadrupler,splitter or EHT module but sounds like the quad....
Digitali
| Posted: Fri May 27, 2011 7:48 pm Post subject: |
Can i swapp the quad from my graphics to test ist ???
The Quad from the Graphics is the older one....
PN... R7722091....
How can i isolate the faillure ????
I don't want damage more then is.....
Digitali
| Posted: Fri May 27, 2011 8:00 pm Post subject: |
Thank you for the link......
In the Data 808s are the new Quad and the EHT.....
My graphics 808s has both of the old one.
Can i swapp the quad between this barcos ????
Is it possible to find a working quad in needed kondition ???
jask
| Posted: Fri May 27, 2011 8:03 pm Post subject: |
to check if you have HV take the cover off and open the large door over the tubes, when you switch the projector on you should see a glow inside the back of the tube near the neck board attachment. this is safe as long as you keep your hands out of there while you do this
| Posted: Fri May 27, 2011 8:07 pm Post subject: |
| Digitali wrote: | Thank you for the link......
Is it possible to find a working quad in needed kondition ??? |
PM Curt he might have one but don't confuse the filament being lit up to having HV to the CRT's...
Digitali
| Posted: Fri May 27, 2011 8:09 pm Post subject: |
There still is a glow in the back of all three tubes.....
| Posted: Fri May 27, 2011 8:20 pm Post subject: |
| Digitali wrote: | | There still is a glow in the back of all three tubes..... |
That is the filament. No filament is always bad news for a CRT tube. It has nothing to do with high voltage.
Digitali
| Posted: Fri May 27, 2011 8:27 pm Post subject: |
Here some pictures from the tubes and from the LEds.
Only on the EHT the Red Led is glowing..... all other Leds are green....
Uploaded with ImageShack.us
Digitali
| Posted: Fri May 27, 2011 8:49 pm Post subject: |
Is there any chance to modify or to repair the quadrupler ????
Its very difficult to find one, and a new one is very expensive.
Much more then i payed for the barco completely...
| Posted: Fri May 27, 2011 10:43 pm Post subject: |
I believe the answer is yes but you need to swap both the working EHT module and quad. Both need to match. Someone please correct me if I'm wrong...
zGman
| Posted: Sat May 28, 2011 1:22 am Post subject: |
Actually - in order to use the earlier style EHT and Quad in the late style chassis -
There is a jumper on the mother board near the EHT and quad connector
that must be moved. There is a Tech sheet on this site with this info.
This isn't difficult to accomplish, unless of course your Barco is on the ceiling.
There is also a compatibility chart which shows workable combinations.
G
jask
| Posted: Sat May 28, 2011 2:13 am Post subject: |
Oops, I missed the line about the EHT light being on, Tom (and Galen ) are right the two parts need to be replaced as a pair- see this link;
http://www.curtpalme.com/docs/BarcoServiceBulletin_R762716_New_EHT.pdf
there is a fuse you can check on the EHT, a bad quad/splitter will usually light up the red LED on the focus board, you could have a bad deflection board or SMPS.
when you switch the power on do you hear any small sizzling or ticking noise back near the EHT area?
| Posted: Sat May 28, 2011 4:11 am Post subject: |
| zGman wrote: | Actually - in order to use the earlier style EHT and Quad in the late style chassis -
G |
I looked for that tech sheet addressing the jumper change but never found it....
Is it in the service manual ?
Digitali
| Posted: Sat May 28, 2011 8:41 am Post subject: |
I've just swapped the old style Quad to the Data 808s/E which has the new style quad......
It does't change anything..... The same faillure still are there.
With the old style Quad..... Both red LEDs on the EHT are buring.....
With the original new style Quad only the upper one was glowing....
