One foot of right side of screen is "streaking"
jeffslife
Posted: Mon May 09, 2011 12:24 am    Post subject: One foot of right side of screen is "streaking"
For lack of an accurate description. Only when I have the OTA tuner on though, when I got the BD playing no problems.
Any help is appreciated.
SC if you comment please PM me.
We are ALL job creators !
Posted: Mon May 09, 2011 12:47 am    Post subject:
It sounds like your H shift/phase control is set too far to the right, and the image is wrapping around itself.
jeffslife
Posted: Tue May 10, 2011 2:55 am    Post subject:
Not sure how to fix it exactly, If I get it set for the OTA wont it mess up the BD picture ?
Posted: Tue May 10, 2011 4:35 pm    Post subject:
You should be using a different channel inside the PJ for each of those. If you like I can send you simple set-up doc. that talks about marquee set-up and how to use the channels, it's actually very easy.
jeffslife
Posted: Tue May 10, 2011 4:44 pm    Post subject:
That would be nice, Thank you
jeff1slife@yahoo.com
Posted: Tue May 10, 2011 5:46 pm    Post subject:
Jeff I apologize but for some reason I keep thinking you have a Marquee. MAybe after reading about all your troubles I was just wishing you had a good marquee.
Anyway, even on the G70 you need to use a different memory block for the BD player vs. OTA broadcast. Reason is they will be require slightly different convergence, geometry, etc. Unfortunately, the only thing I know about the G70 is that I remember reading how difficult the memory blocks are to use. Hopefully someone can explain them in simple tu understand terms.
