Marquee 8500 - Halfine or what?
lighter76
Posted: Sun May 08, 2011 9:45 pm    Post subject: Marquee 8500 - Halfine or what?
I am driving a Marquee 8500. After repairing the LVPS and Vertical Board (replaced) AND changing the green tube, I now have a line in the middle of the screen which is shown by every tube.
I also checked if the line is shown whith a fresh "recall" channel, and the line is there very lightly but not sharp due to the missing convergence. Once I have done the convergence, the line could be seen on a white screen.
As I am sure that this is no mask, do you think that this issue can come by the new vertical board? Did anyonme else have the same problem?
Thx for helping me.
dvh99
Posted: Sun May 08, 2011 10:08 pm    Post subject:
odd, never heard of, post a picture please.
Posted: Sun May 08, 2011 10:22 pm    Post subject:
If the problem wasn't there before you worked on the set, I'd suspect the V board. I can't see it being the LVPS.
lighter76
Posted: Tue May 10, 2011 8:18 pm    Post subject:
after surfing a bit, I found that often the "Bow" geometry settings is the reason and so it was on my side ;-( I just had checked to reduce bow settings from 50 to 38 as 38 did not bring up the line in the middle.
So far so good.
@Curt: As my old, but very well modded Vertical board is out of order, do you know what kind of elements on this board mostly are "burned" by too much power (i think the 15V were much higher as my LVPS was also out of order a few days ago). I am thinking to renew some parts on this board also to learn more about how to solder properly Wink)
dvh99
Posted: Tue May 10, 2011 8:54 pm    Post subject:
do you have another clm to test? my clm doesn`t give me this weird problem.
i do not see this as a vertical board failure but i might be wrong
Posted: Tue May 10, 2011 9:09 pm    Post subject:
None. I will say this to you as well (I seem to say this a LOT lately!). If you do not know how to solder or how to troubleshoot, DO NOT attempt to repair these boards yourself. Repairing any of the Marquee boards requires skill, esp. on the soldering end of things. You will destroy the board if you're new at this, and most techs will refuse to work on a board that has been worked on by someone else.
I know I just wrote off some Barco 909 boards that were destroyed by a 'tech' in the military. Completely destroyed y bad soldering skills, and by replacing a whole bunch of parts that probably didn't need to be replaced.
You really should send the boards to a tech (me, for example Wink) or to someone in Europe that has had experience troubleshooting Marquee circuits.
Posted: Tue May 10, 2011 10:41 pm    Post subject:
"You really should send the boards to a tech (me, for example ) or to someone in Europe that has had experience troubleshooting Marquee circuits."
Shameless plug, shameless.
There's a guy named Gary that........that.........Naaaaa, forget it Laughing
Posted: Tue May 10, 2011 11:21 pm    Post subject:
Hey, I have to! With the lack of donations from the zillions of ads that people are putting in the buy/sell section, I need to get more aggressive. Wink
Besides, Gary woujld somehow add an SDI output to that vertical board, and that's just not required.
Zolzar
Posted: Tue May 10, 2011 11:44 pm    Post subject:
uh oh....so the SDI output I'm paying Gary to put on my Kodak Digital picture frame ........ doh....I'll stop there.
Lighter,
I have had the same issue. I've only really taken note to the line on bright scenes like a bright landscape shot of snow. Just letting you know your not the only one who has seen this problem.
Posted: Wed May 11, 2011 12:33 am    Post subject:
Was the line Vertical or Horizontal?
lighter76
Posted: Wed May 11, 2011 9:26 am    Post subject:
The problematic line was horizontal and came just up when the Bow setting was above 38. So at standard 50 setting the line could be seen in bright pictures. Below 39 this line could not be seeen anymore.
@Curt: I know that you are right...normally I would send in my board. But in this case it is not only cheaper for me to try out the OPAMPS and other ICs to change, I like also the "fun" of soldering. I am not a complete newbie to this. I think the DIODES and Resistors, capacitors I just can check via a multimeter. Only the ICs etc. I canīt test ;-(
Posted: Wed May 11, 2011 3:59 pm    Post subject:
Banding, it's called banding. There's a modifcation the control module to get rid of this.
Posted: Wed May 11, 2011 6:09 pm    Post subject:
That is exactly why I asked. Almost all Marquee's will have banding. Its an arduous process to not have banding.
lighter76
Posted: Thu May 12, 2011 8:10 am    Post subject:
Ok, so I was speaking about "banding". Do you know what the mod of the CLM is to get rid ot his or is it better to live with this issue ?
By the way: I decided not to renew my vertical board ICs etc by myself...i think Curt is right that this is not a simple solder procedure and someone with higher skill level in soldering and testing components should do that Wink
dvh99
Posted: Thu May 12, 2011 12:52 pm    Post subject:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=21198.html
Gannon
Posted: Tue Jun 07, 2011 12:45 am    Post subject:
Way to avoid excessive banding is to never use anything but the manual geometry and convergence...the interpolated/guided point choices cause the halfway and quarterway banding lines. Or at least the majority of 'em.
Cheers
gadfly and rogue philosopher
