linux2
| Posted: Tue Apr 19, 2011 2:39 pm Post subject: Electrohome marquee 8000 green line |
For some reason on my Electrohome Marquee there is a bright line off to the far right of all my tubes. Just at the edge of the projected image. Any way to get rid of this or is this normal? If I turn down the brightness and the contrast it seems to go away on my screen, but if I look at the tube I still see it. It even shows up with no input source plugged into the projector. Either I set something wrong, this is normal, or something is messed up with my projector
| Posted: Tue Apr 19, 2011 3:23 pm Post subject: |
you can also try blanking it out in the "pic menu"
andreas
| Posted: Tue Apr 26, 2011 9:47 am Post subject: |
i have that on my 9500 as well. Blanking wont work because it is in the picture area. I think my is a source problem...
dvh99
| Posted: Tue Apr 26, 2011 10:12 am Post subject: |
http://www.curtpalme.com/ElectrohomeMarquee_Downloads.shtm
click on the
Tech Bulletin: Remove Faint Vertical Line Near Right Edge of Image 0.2mb link and there you go. (3rd from the bottom)
you will need 3* 1.5Megohm 1/8watt (or 1/4watt) resistors for this and some insulation to prevent shorts.
