i1Pro and i1LT simultaneous usage possible in 2.1.1?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
shepardos
Posted: Thu Apr 14, 2011 11:00 am    Post subject: i1Pro and i1LT simultaneous usage possible in 2.1.1?
I tried the 2.1.1 software and get some issues to use this 2 meters together. I have 2 licenses and after reading the realase notes it should be now possible to use this 2 meters together without unplug each of them.
What are the limitations? I could not get those 2 meters to work properly. It is possible that you initialize the meters but you can't switch between this meters in Chroma pur.
I need something like this:
- i1Pro train the 1LT
- i1LT will be used for Gamma/Greyscale
- i1Pro will be used for Color Gamut
all 2 meters should be connected and switchable. Currently I have to exit the ChromaPur and disconnect the other meter to get proper results.
Is there an issue with this setup or is this not currently supported?
Cheers
Shepardos
Rickyj
Posted: Thu Apr 14, 2011 11:08 am    Post subject: Re: i1Pro and i1LT simultaneous usage possible in 2.1.1?
Cheers
Shepardos
You still can't have them plugged in at the same time, but from version 2.1 you do not have to exit the software. You just need to go to the select/initialize meter tab. Press disconnect on this tab, and physically remove the usb. Plug in the new meter, and then initialise, and continue measuring.
This demo shows it quite well: http://www.chromapure.com/demos-21correction.asp
I hope that helps.
shepardos
Posted: Fri Apr 15, 2011 9:59 am    Post subject:
HI Ricky,
Thanks for the heads up. Can you comment why this limitation can't be solved? It would be allot easier if you can chose the right meter for the measurements.
Shepardos
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
