rosenbush
Joined: 14 May 2010 Posts: 94 Location: Brownsville Texas
| Posted: Wed Apr 13, 2011 6:53 pm Post subject: Config for DB-9 <-> VGA (15 pin) for Extron? |
Any one has the correct pin to pin configuration to use de DB-9 on the extron 202xi to VGA conector ?
I know uses a different conf. than the NEC's and so.
Thank's
| Posted: Wed Apr 13, 2011 8:36 pm Post subject: |
Hello
I have special made cables from Better Cables for $40 so why reinvent the wheel?
Tim
rosenbush
| Posted: Wed Apr 13, 2011 10:58 pm Post subject: |
Yeah, I already have 4 set of VGA- RGB cables, and prefer use one of those. Easier to use db-9 <-> VGA. I'll try to use the regular config of VGA. Thanks anyway.
| Posted: Wed Apr 13, 2011 11:31 pm Post subject: |
I can give you the Extron pinouts. Do you have the VGA pinouts?
rosenbush
| Posted: Thu Apr 14, 2011 1:40 am Post subject: |
Got it. Thank's Macg I just find out how to.
Here is
VGA Pin Signal
1 Red Video
2 Green Video
3 Blue Video
4 Monitor ID - Bit 2
5 Ground
6 Red Ground
7 Green Ground
8 Blue Ground
9 [KEY]
10 Sync Ground
11 Monitor ID - Bit 1
12 Monitor ID - Bit 0
13 Horizontal Sync
14 Vertical Sync
15 N/C (Reserved)
Extron 202xi Inputs (DB-9)
Pin Input #1 Signals
1. Ground
2. Red Prime
3. Red Video
4. Green Video/Sync
5. Blue Video
6. Green Prime/Intensity
7. Blue Prime
8. Horizontal Sync
9. Vertical Sync Input
Input #2 Signals
1.Ground
2.no connection
3.Red Video
4.Green Video/Sync
5.Blue Video
6.no connection
7.no connection
8.H Sync/Comp Sync
9.Vertical Sync
So,
DB-9 DB-15
1 <--> 5
2<--> x
3<--> 1
4<--> 2
5<--> 3
6<--> x
7<--> x
8<--> 13
9<--> 14
It may help somebody in the future
