zaphod
| Posted: Fri Apr 08, 2011 3:15 pm Post subject: gray-hoverman antenna |
i've got near line of site to Mt Seymour (home of all the OTA digital antennas where i live) and i'd like to whip up a digital antenna. the G-H seems to be the current winner right now.
i am planning on using 6ga copper for the long receiving arms but for the straight reflector rods what should i use? would 3/4 copper tubing work? is solid better? does diameter matter? i'd use more of the 6ga copper, but i suspect that the rods would sag over time, and that can't be good.
| Posted: Fri Apr 08, 2011 3:39 pm Post subject: |
Why use 6 gauge copper and not steel or aluminum ? One good wind storm and the copper will bend I would think....
| Posted: Fri Apr 08, 2011 3:43 pm Post subject: |
Are the DTV transponders all UHF where you live?
| Posted: Fri Apr 08, 2011 4:12 pm Post subject: |
That was my next question...
| Posted: Fri Apr 08, 2011 5:01 pm Post subject: |
OK, I see that all the DTV stations on Vancouver are UHF... But, what about post-transition? Looks like CA transitions this August... Will some of the DTV transponders be back on VHF, and if so... Your UHF antenna won't work, right?
zaphod
| Posted: Fri Apr 08, 2011 7:11 pm Post subject: |
well it's more fun building something i'll be putting this in the attic so the wind issue isn't that much of an issue.
i don't know about post transition. but i've heard that there are people using the G-H for OTA digital in the US post-transition.
| Posted: Fri Apr 08, 2011 7:41 pm Post subject: |
| zaphod wrote: | | i don't know about post transition. but i've heard that there are people using the G-H for OTA digital in the US post-transition. |
It all depends on the market... In my market, ABC, CBS, and NBC all went back to their VHF transponder post-transition for DTV, whereas they were all using a UHF transponder pre-transition. In that case, your antenna wouldn't work worth a damn.
But, I assume other markets were different than my own.
zaphod
| Posted: Fri Apr 08, 2011 7:47 pm Post subject: |
yeah, i dunno what they are planning to do either
but the US ones in my area mostly stayed up in UHF. one of the FOX and one of the PBS are down in VHF. i doubt that i'd get much other than Bellingham if that.
jeffslife
| Posted: Fri Apr 08, 2011 10:25 pm Post subject: |
ASK an AUSSIE . Them guys build some AMAZING OTA ANTANNAE'S.
| Posted: Wed Apr 20, 2011 12:14 am Post subject: |
It will still work on VHF, but signal strength can vary. I still didn't see why you would need copper. How far are you from the farm?
zaphod
| Posted: Wed Apr 20, 2011 2:03 am Post subject: |
lessee .... probably 15miles or so.
but i've been finding out that 6ga solid copper is a beast to get in this area - only stranded. while Lowes 20 minutes away and across stocks it. sigh.
| Posted: Wed Apr 20, 2011 2:08 am Post subject: |
You might be able to get by with a bow tie. Seriously, it shouldn't take much to get a signal. You can go with GH antenna but that is probably overkill. It might be a fun project though.
