How to attach velvet fabric to screen wall
jbmeyer13
Posted: Tue Apr 05, 2011 10:08 pm    Post subject: How to attach velvet fabric to screen wall
The screen wall in my theater is painted white and rather than paint it black I would like to attach a black velvet fabric to it. What options do I have besides building panels and/or using a staple gun?
I need somthing that is reversable, was thinking of using a spray adhesive. Any thoughts?
Justin
zaphod
Posted: Tue Apr 05, 2011 10:59 pm    Post subject:
there are self adhesive velvets out there. Google is your friend, i thought that i had it bookmarked, but apparently i don't.
LOTREE
Posted: Wed Apr 06, 2011 4:23 am    Post subject:
Hang the velvet from rods?
jbmeyer13
Posted: Wed Apr 06, 2011 3:14 pm    Post subject:
Yeah, I came to the conclusion last night that either I hang it from a current rod or build fabric panels. Using a current rod is probably going to be the quickest and least expensive way to achieve this.
I was already planning to have motorized curtains, so I'll just need a second set of rods for the velvet.
greg_mitch
Posted: Wed Apr 06, 2011 3:26 pm    Post subject:
I was going to get 1/8" hardboard and just cut out basic panels and then use some 3M spray adhesive to put the velvet on them. That way the velvet edge will be straight and solid...I wouldn't want the curtain rod solution because it would likely sway a bit or look a bit loose for my tastes.
dturco
Posted: Wed Apr 06, 2011 6:15 pm    Post subject:
Any adhesive used on drywall will wreck the drywall when/if you remove it. Try screwing in some furring strips where you want the fabric then staple the fabric to the strips. That way if you want to remove the fabric later all you have to do is fill in the little screw holes in the drywall.
The assumption is you screw into your ceiling joists or use the proper sized anchors.
http://www.hulu.com/firefly
jbmeyer13
Posted: Thu Apr 07, 2011 2:07 am    Post subject:
Thanks Dturco. I'm going to use the furring strips with a combination of staples and industrial strength velcro since I need access to the screen wall in certain locations.
Boilermaker
Posted: Sat Apr 09, 2011 1:53 pm    Post subject:
Been awhile since I have seen it, but decorators years ago used to hang fabrics on walls just like wallpaper by using wallpaper paste.
Bob
jbmeyer13
Posted: Mon Apr 18, 2011 2:59 pm    Post subject:
I had considered that but I need something that is removable; since the screen wall contains a window. If I glue Velcro strips to the velvet I can then make removable sections. I figure the furring strips will be the least invasive method.
StudioJim
Posted: Tue Jul 05, 2011 10:40 pm    Post subject:
Thanks for this. I was wanting to do something similar in my home theater and I think this solution will do the trick. I will let you know how it goes! Thanks again.
The home theater construction project never ends! Any advice on seating would be appreciated. I know http://www.familyleisure.com/Home-Theater-Seats sells them. Any other ideas?
Proud owner of a Sony VPH-D50 CRT projector
LandoM
Posted: Mon Jul 11, 2011 3:21 pm    Post subject:
How are you going to cover the staples on the furring strips? You could put some moulding or furring strips over the furring strips under the velvet and have them screwed in. It would create a framed look on the wall. The one thing I hate about glueing is trying to keep the fabric from wrinkling or the glue coming through. I know I've seen some fabrics with a foam backing that would be easier to glue as well as preventing wrinkles but I don't know if there is a velvet fabric one.
Lando - For those who live in Phoenix, do you use dish tv phoenix or another provider?
jbmeyer13
Posted: Mon Aug 15, 2011 6:15 pm    Post subject:
I only stapled the along the top and it's impossible to see. I let it hang down naturally and left enough length at the bottom so I can conceal the speaker wires.
MarkLB
Posted: Thu Jun 05, 2014 5:45 am    Post subject:
This is a great device! I found some more information on this website: http://www.archiexpo.com/architecture-design-manufacturer/velvet-fabric-2128.html
