HDFury3 and Sony G90
drjon
Posted: Mon Mar 28, 2011 10:54 pm    Post subject: HDFury3 and Sony G90
I have HDFury3 hooked up to a Sony G90 vis 5xBNC input. If I select RGB on DIP on HDFury G90 says signal is out of range and cannot be displayed. The source is Sky HD box. I can only get a stable green picture by setting the DIP to component input. I have tried connecting directly and through a switcher, same result. Tried various combinations without success. Have also tried adjusting output from Sky box yo no avail. Adjusting Sony clamp setting does not help. Any ideas would be much appreciated.
Posted: Mon Mar 28, 2011 11:02 pm    Post subject:
What transmission standard does a Sky HD box in France use ?
drjon
Posted: Mon Mar 28, 2011 11:06 pm    Post subject:
Actually the dish is pointed at Sky UK, and the box has Scart and HDMI and composite outputs. The Scart can be set to PAL or RGB. I assume that the standard is PAL as that is what is used in the UK and Europe as far as I know. I hope this answers your question. Thanks.
