tse
| Posted: Wed Mar 16, 2011 1:47 pm Post subject: Barco neck cards and G-2 |
Barco CRTs usually (always?) have G-2 connected on pin 6.
Some CRTs have G-2 connected on pin 2.
If one connected pin 2 of a non Barco tube to pin 6 to allow use of the non Barco tube in a Barco projector would the fact that G-2 voltage being on pin 2 cause a problem?
Is pin 2 connected to anything on barco neck cards?
TIA for the help,
Scott
Thomas Jefferson
| Posted: Wed Mar 16, 2011 3:40 pm Post subject: |
Nope, I've done it with no problems.
| Posted: Wed Mar 16, 2011 3:44 pm Post subject: |
AFAIK, this is done all the time. MArquee tubes in a Barco and vice versa. Pin 2 on a Barco is open as is pin 6 on marquee tubes. I have installed one Barco 180DVB in a MArquee and jumped 2 to 6 by moving White bias wire. You do the opposite for MArquee tubes in a Barco.
Lets have some Barco guys confirm .
tse
Thanks, Curt. You're a gentleman and a scholar.
Scott
Thomas Jefferson
tse
| Posted: Wed Mar 16, 2011 3:51 pm Post subject: |
Draganm, we posted at the same time.
You have to watch-out when connecting G-2 to pin six on a Marquee neck card as there is a few hundred k ohm resistor (if a non LUG neck card) to ground there. It will load the Marquee G-2 circuit and potentially not allow the voltage to go high enough.
It seems that isn't the case with the Barco neck card as pin 2 must be open circuit. Curt sez no problem there.
Scott
Thomas Jefferson
Ile
| Posted: Wed Mar 16, 2011 4:06 pm Post subject: Re: Barco neck cards and G-2 |
| tse wrote: | | Barco CRTs usually (always?) have G-2 connected on pin 6. |
Only Mec tubed Barcos I think.
| tse wrote: | | Is pin 2 connected to anything on barco neck cards? |
Most unused pins are tied to ground, in some models that is also case with pin2. For example in 1208 it's connected to ground.
If I remember correct it was same thing with my BG808s neck boards (originally Sony tubes).
So it's good to check first.
tse
| Posted: Wed Mar 16, 2011 5:50 pm Post subject: |
Oh, oh. Is it that some Barco neck cards have pin 2 grounded and other Barco models don't? I don't know which projector these tubes are going in other than Barco.
Scott
Thomas Jefferson
