Panasonic PT18-244
Decibel
Posted: Tue Mar 15, 2011 1:18 pm    Post subject: Panasonic PT18-244
I just bought the tube in subject
I read other posts and it could be compatible with R762746 neckboard.
Comments?
Domenico (Barco fan!)
Blockbullie
Posted: Thu Mar 17, 2011 5:31 pm    Post subject:
I seen that on ebay to and was wounding If It was for a909 ?
Rich mans taste with a poor mans wallet
Posted: Thu Mar 17, 2011 5:33 pm    Post subject:
Nope, the housing is wrong and the PT18 dictates that this is an 8" tube. A 9" tube would be a PT22
Decibel
Posted: Thu Mar 17, 2011 5:46 pm    Post subject:
In the meantime I found some information about this tube. It was mounted on a retroblock 808. I will pull from that LC housing and put in another LC housing with the scheimpflug adjustment.
Blockbullie
Posted: Thu Mar 17, 2011 9:18 pm    Post subject:
Surprised I ment that.....hahahahahahh Laughing
Posted: Tue Mar 22, 2011 3:09 pm    Post subject:
A man who has a BG808 (20k in the set) asked me to retube his machine... (I never saw a Barco Very Happy) But we found a source for a good set of PT18-244 tubes with lenses. Can I swap simply the housings (in meantime AC->LC) or would need tinkering? The pinout is compatible with the 180's?
Decibel
Posted: Tue Mar 22, 2011 3:36 pm    Post subject:
I think that PT18-244's is a native LC tubes, so they have LC chambers and c-elements.
The pinout could be compatible with 180dvb's tubes.
If you want to mount LC barco's tube in the BG808 you must make adapters like these ....
(look adapters only)[/img]
Posted: Tue Mar 22, 2011 4:03 pm    Post subject:
Did you do these adapters? Are the dimensions of it top secret? Smile
What do you mean on they are native LC tubes, should I transplant these tubes into the 180dvb-s housings if I don't want to tinker with adapters?
Decibel
Posted: Tue Mar 22, 2011 4:21 pm    Post subject:
A my friend did adapters for me. I must seek plans with dimensions. The Green adapters are different because blue and red are overlapped on the green as you can see in the pictures.
Yes ... if your tubes are LC you must do adapters or transplant in AC housings (without adapters of course).
Posted: Tue Mar 22, 2011 4:30 pm    Post subject:
Cool thanks!
You dont have to hurry with the plans, because we didn't decided yet which way we'll go
Blockbullie
Posted: Wed Mar 23, 2011 4:46 am    Post subject:
Does anybody have the pin out diagrams for a barco 1208 and a 808s
Posted: Wed Mar 23, 2011 6:56 am    Post subject:
I don't know 1208, but the 808 uses almost the same pinout as marquees(can be found easily), the difference is that G2 is connected to pin 6 on barco-s
Decibel
Posted: Mon Mar 28, 2011 1:13 pm    Post subject:
The green tube is just delivered. I think it's new. It have no burn Very Happy
Part number is R7627115K Thumbs Up
Decibel
Posted: Thu May 26, 2011 7:34 am    Post subject:
I removed the tube from his 8" LC housing (without scheimpflug).
Soon I'll put in the new housing (with scheimpflug).
For crt fans: be careful when you insert the tubes into the housings because there are very little spacers that hold the tube in place (correct distance between tube surface and c-element).
In the pictures you can see these spacers (two types).
Decibel
Posted: Sat Jul 02, 2011 9:22 am    Post subject:
I just put the PT18 in LC chamber with scheimpflug Thumbs Up
secstate
Posted: Sat Jul 02, 2011 4:57 pm    Post subject:
As a bonus I believe the PT-18s are the higher resolution 8" tubes like the P16LNP/LNQ, etc. If the ceramic insulators on the gun are white/white then they it is a higher res tube from what I understand. Makes a huge difference for Hi-Def. The P16s which I put in a Data 808s from an Ampro retro were the single biggest improvement I made to my 808s when I had it .
Decibel
Posted: Sat Jul 02, 2011 5:15 pm    Post subject:
I have only green PT18-244.
I have a complete set of P16LNP also.
In your opinion what's the best?
secstate
Posted: Sun Jul 03, 2011 12:38 am    Post subject:
I have seen both PT18s (which were stock in the 1208s/2 series) and P16LNQs (which I believe are the same as LNPs but with different hardware for an Ampro retro) and they seem to perform the same to me at least within the limitations of what I could resolve with HD8s and my CRT setup (dis)abilities (both were better than the 180DVBs). If they are both white/white ceramic insulators vs. the pale yellow of the 180DVBs then they are high res tubes and I would just go for which ever tube was better condition-wise.
dvh99
Posted: Sun Jul 03, 2011 1:07 am    Post subject:
i think the pt18 is with fast decaying phosphoresense like the pt22 9 inch version.
if you want 3d in the future i would go with the pt18 tube.
Dave Lister
Posted: Sun Jul 03, 2011 12:15 pm    Post subject:
I have a set of PT18-244's and they have the dual white ceramic insulators, they are also very minty.
What are they worth? I will be parting out the projector (Barco G808s Retroblock) they are from as changes in my life mean I won't be putting it back together. Crying or Very sad
Stuff for sale;
