Esel
| Posted: Mon Feb 21, 2011 12:47 am Post subject: Need settings for LumagenDVI and Barco 808 with HDFury3 |
Hi folks,
got a new toy. A LumagenDVI and can't get a 1080i Out-res.
BR Player (DMP-BD30) forced to 24p. Output res 1080i.
With 480p on the Lumagen i have an image. If i'm switching to 720p/1080i the Barco won't sync.
Have someone settings for the Lumagen and the 808?
thx
Andreas
Esel
| Posted: Mon Feb 21, 2011 7:34 am Post subject: |
Thanks. The Fury3 is handling the sync and is forced to pos.
Refreshrate is 59.94
kschmit2
Esel
| Posted: Tue Feb 22, 2011 12:13 pm Post subject: Image again |
@kschmit2
are you sure my VisionDVI can output 96hz?
Anyone with timings that work?
thx Andreas
Esel
| Posted: Tue Feb 22, 2011 1:11 pm Post subject: haha hahaha |
Guys, this is great.
I've changed the sync on the fury because i read the pins upside down
Anyway i got in image again but any resolution i can choose is 480p.
Found an issue with fury3. Hope ill get an EDID-Update that fix the problem.
Otherwise the Fury2 has fixed the issue by the other guy.
THX
Andreas
Esel
| Posted: Wed Feb 23, 2011 9:33 pm Post subject: |
Allright. Heres the fix.
As i've set the VisionDVI to Sync H-V- and Scale to Pass and the Sync-Force on the Fury to OFF it worked.
Now i have 1080i@71.93hz with 24p. Grrrrreat
Now i will tweak around a bit.
thx
Andreas
Esel
| Posted: Thu Feb 24, 2011 3:04 pm Post subject: |
Cool, will try in a few hours.
Andreas
Esel
| Posted: Fri Feb 25, 2011 2:21 pm Post subject: |
@all
thanks for the support. Will do the 96hz with settings from kschmit2 again on monday.
Has tested ist but noticed a weird stuttering in the whole image.
Deleted it and noticed later on that it only come up if OSD is shown.
br and a happy weekend
Andreas
Esel
| Posted: Mon Feb 28, 2011 8:08 am Post subject: |
So, i have trouble with the settings mentioned above.
If i set aspect at 2.40 and timings and refreshrate i'll get a stuttering and flickering image.
Also at 71.93Hz the image stutters. The res says 1080i if i change it to 800 the CRT won't sync.
Chain is Panasonic DMP-BD60, Marantz SR4002, Lumagen, HD-Fury3.
Any suggestions?
Andreas
kschmit2
| Posted: Mon Feb 28, 2011 9:44 pm Post subject: |
| Esel wrote: | @all
Hi Andreas,
I also have those stutters when the Lumagen OSD is active. Once it is gone, everything is perfect again. That's just a cosmetic problem, and I can live with it.
Kai
Esel
| Posted: Tue Mar 01, 2011 8:01 am Post subject: |
Kai, can you please tell me a step by step lesson how i have to set it up.
I think i haven't done the sqeezing right.
What i've done is...
1. Set 2.40 Aspect
2. Set 96.00 Ref-Rate
3. Set your Timings
4. Then i've tried to bring the image onto the screen properly but haven't used the shrink-option.
How did i use the dhrink-option correctly?
Andreas
kschmit2
| Posted: Thu Mar 03, 2011 9:44 am Post subject: |
well, my timings are not for active area scanning. They are for a 16x9 setup.
I have never played with active area scanning.
Person99
| Posted: Fri Mar 11, 2011 4:50 pm Post subject: |
IIRC The VisionDVI will not do 1080i/96. It will do 1080i/72. The HDP will do 96.
Secondly, the video processing and the chip in the DVI is not as good as the HDP. What is your souce? With anything but 1080p/24 you are unlikely to be able to get the DVI to lock onto the film cadence and covert to 72 correctly, you will get the tearing you mention.
To feed the DVI 1080p/24 and get a good 72 out takes some more tweaking with the the DVI than the HDP. It can be done, but takes some work.
_________________ Dave
JamesAB
Joined: 15 Jan 2011 Posts: 56 Location: New Hampshire
TV/Projector: Marquee 8000
| Posted: Fri Mar 11, 2011 5:24 pm Post subject: |
Can either the Lumagen DVI or Lumagen HDP output 1080p/72 ?
dturco
| Posted: Fri Mar 11, 2011 5:33 pm Post subject: |
| JamesAB wrote: | | Can either the Lumagen DVI or Lumagen HDP output 1080p/72 ? |
No only the Radiance + Models can do 1080p@72hz.
The Vision series caps out at 1080p 60hz.
The Vision Pro can do 800p/817p@72, 960p@72.
This is at the limit of the DVI specs. 148.5 Mhz?
http://www.hulu.com/firefly
AVphile
Joined: 02 Dec 2008 Posts: 334 Location: Ottawa, Ontario
| Posted: Fri Apr 01, 2011 3:28 pm Post subject: |
| Esel wrote: | The res says 1080i if i change it to 800 the CRT won't sync.
Any suggestions? |
Is the Fury a limiting factor here? I doubt they tested it at every res.
_________________ AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
