Murillo
| Posted: Mon Feb 14, 2011 8:14 am Post subject: Thin line inside image from top to bottom at 720p and 1080p |
Hello Everybody
Itīs getting a bit complicated to set up my PJ with the moome. When I look in to the tube I get banding on the left side (Which I donīt think has anything to do with the moome). On the right side a get a thin white line that goes from top to bottom. Itīs about five millimeters inside the image and is there on all three tubes. It moves with H-phaze and raster shift, always on same spot and is present at 720p and 1080p. I did a quick setup trying 1600x900 and the thin line is still there, but at the end of the image and can be solved with blanking. 1600x900 is not the same as 1920x1080 and I would like to use 1920x1080p.
I use HTPC with Radeon HD 5550 plugged in to the ext. Full HD v.3 and then in to a Barco 1209. I donīt use powerstrip since it caused problems and gave me frame drops.
Has anybody experienced this? I donīt know if there is something wrong with my moome or projector, or maybe I just donīt set it up correctly? I would really appreciate an answer.
Best regards
