Murillo
| Posted: Sat Jan 22, 2011 7:44 pm Post subject: Output sync problems with powerstrip |
This is starting to be really difficult. But I still won`t surrender to the greyside. I run a HTPC through the Moome ext full hd v.3 and have problems with wrapping image on my Barco 1209 when I set to 1920x1080 60hz. I didn’t use Powerstrip but now I installed it and are able to adjust the back porches but the playback jidders a lot. Like it is showing every second image of the movie I think It has to do with the output sync settings. The Moome is set to negative on both h and v. It doesn’t matter how I set powerstrip the playback is the same. Does anybody how I should set the output sync on the moome or isn’t that what’s causing the problem?
Best regards
