Importing RS232 into SIMPL
tri_joel
Posted: Fri Jan 14, 2011 3:14 pm    Post subject: Importing RS232 into SIMPL
I know there are still a few Crestron people here. I just received a 4 x 4 Matrix HDMI switch from Monoprice. It included a CD with the the RS232 program, but I don't know how to install the Matrix information onto my User Database in SIMPL.
Any help greatly appreciated.
Joel
www.vawinesnob.com
Axatax
Posted: Sun Jan 16, 2011 10:35 am    Post subject:
What is the "martix information"?
If this is a SIMPL module, do you *really* want this in your user DB? -- Are you _sure_ ? If so, you can place it into \Program Files\Crestron\Simpl\Usrmacro, and any SIMPL+ in \Program Files\Crestron\Simpl\Usrsplus.
These modules should really be placed into the same path as your program, so they follow your SC.
tri_joel
Posted: Sun Jan 16, 2011 11:51 pm    Post subject:
Humm, maybe I'm not understanding how this works. For my BG 1208, I just opened the Crestron db, located the 1208 rs232 program, and placed it into the rs232 port on my CMNSXAV. I guess I was thinking the disc that came with the Matrix switch contained the communication information to place into my user db, then I could just drag and drop it into the rs232 port.
It sounds like that is not the case?
www.vawinesnob.com
akajester
Posted: Mon Jan 17, 2011 2:22 am    Post subject:
More than likely you'll need to figure out how to communicate to it (info in the manual?) and just send the strings to it over serial. I doubt something from Monoprice would have a crestron component.
Dale
Axatax
Posted: Mon Jan 17, 2011 9:16 am    Post subject:
tri joel,
Send me the files from that Monoprice CD and I'll write a Crestron module for you.
Don't ever do this. This is most likely a 2-way device and you'll want to process the feedback, regardless of whether or not you're ruining a 2-way panel.
Keep in mind I don't have this hardware so we might have to go back and forth a few times to get this 100%. I can do Skype or POTS, etc.
What processor are you using? I have a CNMSX AV (ST-CP generation) and AV2 at my disposal.
Axatax
Posted: Tue Jan 18, 2011 12:29 am    Post subject:
Tri Joel,
YGM.
fuzzybee
Posted: Mon Feb 28, 2011 6:53 pm    Post subject:
Axatax wrote:
tri joel,
For something like a matrix switcher, unless you plan on switching routes on the front panel, there's typically no need to worry about processing any feedback. Not sure why you would tell people otherwise.
weldywire
Posted: Thu Mar 10, 2011 4:13 am    Post subject:
Did you ever get this controlled with Crestron? I would consider purchasing the 4x4 if its working under Crestron for you.
tri_joel
Posted: Thu Mar 10, 2011 5:31 pm    Post subject:
No, I have not got it working yet. I am having other issues with my control processor and finding time to work on it. I'll post an update if/when I get it working.
www.vawinesnob.com
