ChromaPur 2.0.3 and Radiance Testpattern?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
shepardos
Posted: Thu Jan 13, 2011 3:31 pm    Post subject: ChromaPur 2.0.3 and Radiance Testpattern?
I use ChromaPur 2.0.3 to calibrate my JVC X3. The Radiance can be used as test pattern generator but unfortunately he picks up only the reference pattern and not the adjustable pattern.
How can tell ChromaPur that he should use the adjustable test pattern?
Shepardos
TomHuffman
Posted: Thu Jan 13, 2011 3:50 pm    Post subject: Radiance Test Patterns
We are aware of this problem.
It will be fixed in our next release, 2.1, which I expect to get out by the end of the month.
ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
shepardos
Posted: Fri Jan 14, 2011 9:11 am    Post subject:
Thanks Tom,
Does this release also include the Automatic-Calibration Feature or do you know when this will be released? It would also be fine if you can use 2 Meters (i1Pro & i1LT) simultaneous, rather than quit and always initials the meter again.
mechman
Posted: Sun Jan 16, 2011 4:10 pm    Post subject:
2.1 will be the pre-cursor to the auto calibration release. So no auto calibration with 2.1.
shepardos
Posted: Tue Feb 08, 2011 12:51 pm    Post subject:
Any news about the 2.1 release?
TomHuffman
Posted: Tue Feb 08, 2011 3:46 pm    Post subject:
Very soon. We are in testing now.
TomHuffman
Posted: Sun Feb 27, 2011 10:12 pm    Post subject: Re: ChromaPur 2.0.3 and Radiance Testpattern?
Shepardos
Shepardos:
I just tested this, and ChromaPure is generating adjustable test patterns. As you adjust the values on the grayscale/gamma or the CMS areas of the Radiance using the Radiance test patterns the readings change as expected.
What steps did you take that lead to believe that the patterns were not adjustable?
-TH
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
