how to set custom resolutions with Lumagen Radiance XS
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products
ElTopo
Posted: Sat Jan 08, 2011 6:33 pm    Post subject: how to set custom resolutions with Lumagen Radiance XS
Hi all,
i cannot find a way to set the Radiance XS to a custom resolution like 720p@120Hz or 720p@96Hz.
Service Mode is on.
Maybe it's not possible at all ?
thanks for input
ElTopo
Barco Cine 9 the one and only
ElTopo
Posted: Sat Jan 08, 2011 6:38 pm    Post subject:
Inside the Timing menu i'm only able to toggle between 50Hz or 59,94Hz
Posted: Sat Jan 08, 2011 7:25 pm    Post subject:
Make sure your in the output menu for timings. It s a bit difficult at first to follow the menu path, but once you explore it you'll figure it out.
Also make sure you enable the service mode. Because I play with different timings a lot i set service mode into permanent so I can access
all options.
At work now so i can't look at the menu tree to guide you along.
ElTopo
Posted: Sat Jan 08, 2011 10:55 pm    Post subject:
thx for reply.
Service Mode is enabled, but no success inside the Timing
menu.
Can you put a numeric value in the refresh rate field with the remote
or are you only able to toggle between some available values?
Maybe it has to do with EDID of the HD Fury1?
ElTopo
Posted: Sat Jan 08, 2011 11:02 pm    Post subject:
Hmm, I was able to put in my own numbers. The EDID might be the reason as you mention. i was using a moome internal card and also a moome MUX before the lumagen.
ElTopo
Posted: Sat Jan 08, 2011 11:14 pm    Post subject:
I'm not on the newest Firmware but that cannot be the problem?
With the old Lumagen HDQ it was not a problem.
ElTopo
napos
Posted: Fri Jan 14, 2011 12:04 pm    Post subject:
You have to make a calculation first. You have to multiply the Horizontal X Vertical Pixels X the Framerate (Hz) to get the Bandwidth.
For example for 720P@120Hz you would have to do :1280 X 720 X 120. When you get the bandwidth that is required, input it, and your framerate will show 120Hz. It is a little bit different than the HDP was and I had a tough time doing it at first. Talked with Jim at Lumagen and had it running in a minute.
Let me know if you need any more help.
Nicholas
Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
Posted: Mon Apr 11, 2011 4:32 am    Post subject:
http://www.cir-engineering.com/bin/clock_calc.xls
CxTurbo
Posted: Wed Apr 20, 2011 5:51 pm    Post subject:
Thanks for that spreadsheet Craig. I have a question though. I would like to try an interlaced output. 1080i96 to be exact. What is the best way to go about that? I have not seen anything that jumped out at me to get interlaced resolutions on the net or here with the radiance family of processors.
Paradigm Studio 100's,Studio 20's,CC-690, Paradigm DSP-3400 V1 SUB
Pioneer Elite SC-35 AVR
Pioneer Elite BDP-05FD Bluray
3x Bryston 3B's
URC Complete Control Medius TX-1000 Remote
HTPC (LGA775 Q6600, 8GB DDR2, 7TB Storage) Mediaportal
Lumagen MINI 3D
Moome FULLHD-EXT V2
Audioquest Cable Top to Bottom
9501LC
nidi
Posted: Wed Aug 08, 2012 7:55 am    Post subject: Pixel CLock Limits in your Calc Sheet
Craig,
donwload your clock calc sheet and noticed that you mention that the clocl rate has to stay
below 148500000 Hz.
is that G90 specific ?
Usually a 1080P/60 setting is much higher than that and 72/75 Hz even higher
can you elaborate on that please?
Michael
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products All times are GMT
