jeffslife
| Posted: Sat Jan 08, 2011 12:22 am Post subject: Does it help to warm up on white screen ? |
Or should it be a moving picture ? Does a moving pic wear the tubes more ?
I read somewhere that the tubes wear even when the pj is in STANDBY , is that true ?
LOTREE
Joined: 19 Mar 2006 Posts: 401 Location: Paradise, Newfoundland
| Posted: Sat Jan 08, 2011 12:56 am Post subject: |
A white screen will warm up the tubes faster and burn them faster. It's not something I'd suggest doing all the time but I have at times. Regarding image burn, the tube face is still being traced the same number of times regardless if the image is moving or not but in different areas leading to a more even, extended wear. The difference being a static bright image can spot burn, eg. windows login, taskbar, channel logos, etc.
If the projector is in standby there should be no phosphorus wear. You could have 20,000 standby hours on a chassis yet only 2000 on the tubes.
_________________ Zenith Pro 1200x | Electrohome ECP 4500 | Yamaha HTR-5740 | HTPC & Speaker build to follow
dvh99
| Posted: Sat Jan 08, 2011 1:57 am Post subject: |
i never bothered, just turn on the pj and watch a movie or play a game, that is what i do anyway.
converging should be done on a warmed up pj however but you will most likely know that.
ChrisWiggles Opinionated SOB
| Posted: Sat Jan 08, 2011 3:57 am Post subject: |
Most of the warm-up is electrical drift which happens regardless of what the picture is.
The phosphor tube surface itself will not wear if there is no image being projected.
As far as "standby" wear on the chassis and other aspects of tube life, it depends on what projector you're talking about. Some use "standby" basically to refer to OFF and waiting to be powered up via remote control. Others use "standby" to mean fully powered on but with the image muted, and chassis hours are accruing and the unit is totally on just no image. So it depends.
jeffslife
| Posted: Sat Jan 08, 2011 4:09 am Post subject: |
I meant standby as off waiting to be turned on by remote.
So there is no tube wear on a white screen ? Or is the white screen considered an image ?
It is right ?
| Posted: Sat Jan 08, 2011 4:11 am Post subject: |
White screen absolutely wears, the most. It just does so evenly.
If standby is equivalent to off, then there is no phosphor wear at all.
jeffslife
| Posted: Sat Jan 08, 2011 4:17 am Post subject: |
cool. Thank you.
I have another g70 with about 5000 hrs but it has Windows Vista logo burned in
would running a white screen help to minimize that ?
| Posted: Sat Jan 08, 2011 5:39 am Post subject: |
It depends how bad. If it's only very very slight, it would help some. But if it's burnt bad, it's not going to do too much. All you're really doing is wearing everything and trying to make everything slightly more equally worn-out.
It's like having one worn-out tire. You could drive around for 50K miles and then have all your tires pretty worn out, but one particularly bad. But because they're all worn now, maybe you don't notice it quite as much. But it doesn't fix anything and it doesn't get you a new tire...
Others have played around with trying to wear an inverse image in to help out, but not sure anyone's had much real luck with that. That's like wearing just three of your tires, so now you have four equally worn-out tires. But not sure anyone's been truly successful at that.
richardc
| Posted: Sat Jan 08, 2011 8:33 am Post subject: |
Hi Guys
I believe it has more to do with the mechanical coupling with the Hybrid Lens (Glass and Plastic) as they heat convergence changes slightly.
But I still turn my 30 min warm up off.
Also the Vertical and Horizontal Amps will have to stabilize to.
Regards
Richard
| Posted: Sat Jan 08, 2011 4:03 pm Post subject: |
Jeff,
You may want to try to even out the wear to reduce the logo. Like Chris said, it just wears the rest of the phosphor to the level of the logo, but it would make it less noticeable.
jeffslife
| Posted: Sat Jan 08, 2011 4:06 pm Post subject: |
Any ideas on the best way to do that ?
dturco
| Posted: Sat Jan 08, 2011 4:09 pm Post subject: |
| jeffslife wrote: | | Any ideas on the best way to do that ? |
Sure Jeff,
Try this on for size.
http://www.curtpalme.com/Balancing_CRT_wear.shtm
I think it works fairly well but it's beyond what i am willing to try... or should i say have the patience to try.
http://www.hulu.com/firefly
AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Sat Jan 08, 2011 8:05 pm Post subject: |
I run the white screen warm-up for 1 min. until the image stabilizes then switch to a full screen (16:9) OTA HD signal and finish off with that. I use a macro programmed on my remote.
IMO the white screen left on too long may stress the PJ more than necessary. It falls along the same line that you color calibrate greyscale with a 20 or 30% square verses full screen.
