didaschi
| Posted: Mon Jan 03, 2011 10:37 am Post subject: Sony G70 and HDMI Moome Card, no signal on blue tube |
I got a Sony G70 with the latest HDMI Moome Card inside with nearly new tubes.
The seller told me that the card must be damaged and I only could use the standard RGB Input or a HDFurry for Bluray.
I checked the Moome Card on my old G70 with bad tubes and it run without problems.
So there must be a problem in the G70. If possible I will not change the good tubes to my bad G70 I will try to find the problem and change the damaged board and hold my old G70 as backup.
What boards you would recommend to change first?
By the way the seller told me that he had to change B-Board month ago . May this be the reason for no signal via IFB-Board?
Best wishes
didaschi
