G90
quest_enterprises
Posted: Wed Dec 29, 2010 10:18 pm    Post subject: G90
What are some possible issues when a G90 shuts off when you turn it on?
Quest
jarseneau
Posted: Wed Dec 29, 2010 10:34 pm    Post subject:
Do you see an error code on the back panel numerical display?
There could be many reasons but my most recent adventure of this sort started when I did the fan mod and the fan at the front of the projector stopped and the mod fan didn't cause the proper shut down. That resulted in some blown transistors.
Did you do a fan mod? Does the familiar crackle of high voltage fail to happen on power up?
Jerry
HaydnG90
Posted: Thu Dec 30, 2010 3:21 pm    Post subject:
Could be any number of things. Knowing the code will help to define the problem. Just be careful when you read the display when its up on the ceiling. The number reads correctly when viewed floor mounted.
quest_enterprises
Posted: Fri Dec 31, 2010 2:06 am    Post subject:
Thanks everyone for the information.
Quest
