| Posted: Mon Dec 27, 2010 11:43 pm Post subject: "Chip Clip" for surface mount ICs? |
Guys!
I have a device here that is spring-loaded and straddles a DIP IC with pins sticking up, so you can clip your scope probe or voltmeter to the pins. Is there such a clip made for surface mount ICs? It occurs to me that putting 3 volts onto IC17 would let one replace Marquee lithium control board batteries without losing the settings. Without a clip it would be necessary to solder leads to the pins on the IC itself.. The pads for the battery do not lend themselves to trying to solder there. I have been trying to get Librarian and VDC loader to run on my laptop and they are giving me fits........
phishin_ca
Joined: 17 Mar 2009 Posts: 64 Location: Salisbury, MD
phishin_ca
| Posted: Tue Dec 28, 2010 12:42 am Post subject: Re: "Chip Clip" for surface mount ICs? |
| Tim in Phoenix wrote: | Guys!
Hey, keep your twisted geeky tech porn fetishes to yourself, would ya?
| Posted: Tue Dec 28, 2010 12:43 am Post subject: |
| Nashou66 wrote: | What USb to RS 232 adaptor are you using for the marquee loader program?
Athanasios |
Uh, none. A 9 pin cable both ends should work, but the error comes back "projector not responding". My laptop talks to the DVX processor okay, so I am stumped.
| Posted: Tue Dec 28, 2010 12:44 am Post subject: |
Is this a cable you used before? There are several 9 pin cables, straight through and null, and the null one has a number of configurations, If it's an old cable, check the continuity, if it's a new one, it might not be configured correctly.
| Posted: Tue Dec 28, 2010 12:53 am Post subject: |
This one should handle it, Thanks!!!!
phishin_ca
| Posted: Tue Dec 28, 2010 12:58 am Post subject: |
No problem!
phishin_ca
| Posted: Tue Dec 28, 2010 1:21 am Post subject: |
I could have one drop shipped to ya tomorrow
