Murillo
| Posted: Thu Dec 23, 2010 12:08 pm Post subject: Howto set gamma/brightens to neutral on ext v.3 |
I recently received my moome ext full HD v. 3 and would like to know how to set the gamma and brightness controls to neutral? I would like to make the installation on the PJ with the card set on neutral and afterwards set the gamma. I wouldn`t like to mess with the moome`s brightness setting at all. For that I would like to use the PJ:s brightness control.
Best regards
JustGreg
| Posted: Thu Dec 23, 2010 12:31 pm Post subject: |
I'm far from an expert as I just got an EXT v2 but from what I've learned you have to turn the gamma and contrast screws counter clockwise until a very faint click is heard. (My hearing sucks so I never did hear that sound)
The pots are continuous/infinite so there is no real 'stop' where the screws will just hit the end of travel. Keep in mind you can turn those suckers for what seems like forever before seeing anything happen on the screen but they do work. The range of travel is something like 20 turns so it's easy to think they don't do anything.
_________________ Greg
WTS
| Posted: Thu Dec 23, 2010 1:56 pm Post subject: |
Typically the Moome cards come set to what you refer to as neutral.
_________________ Thanks
Walter
Murillo
| Posted: Thu Dec 23, 2010 9:02 pm Post subject: |
Thank you for your quick reply.
