Marcel_D
| Posted: Fri Dec 17, 2010 9:02 pm Post subject: Aspect ratios - what the heck? |
All right so the raster on my trusty old NEC 9PG+ is set beautifully to resolve the aspect ratio that some people may refer to as 16:9. When I set it up I figured sure, this would be the sweet spot. I can still send some 4:3 and some 2:35:1 content into the pj and not create some horrible wear on the tubes. That was before I actually owned a single Blu Ray. I kind of acquired the projector and Blu Ray at the same time and now I'm thinking I made a mistake. I'd say 90% of my HD movies are cropped/filmed at 2:35:1 and I think I played 1 4:3 movie through it so far.
I'll start by asking why? Why is this extreme aspect ratio deemed necessary for modern movies? And now I don't know if setting the raster to that ratio is worth it. I mean, that's getting a little thin isn't it? Let's see, 2:35:1 = 4:1.7, so almost half of the 4:3 tube face vertically is not being used. What aspect ratio do most people have their CRT projectors set to?
Marcel_D
| Posted: Fri Dec 17, 2010 10:19 pm Post subject: |
That's a good idea. Just wondering how close to the edges is it safe to go? I know smaller raster means you can run it closer to the edge, but how close is that? Next thought, that would reduce the light output and soften the image right?
| Posted: Fri Dec 17, 2010 10:25 pm Post subject: |
| Marcel_D wrote: | | That's a good idea. Just wondering how close to the edges is it safe to go? I know smaller raster means you can run it closer to the edge, but how close is that? Next thought, that would reduce the light output and soften the image right? |
Using a 2.4 aspect reduces light anyhow just by its shear size, the only thing is you'll not be able to fit 1.78 in that area. Unless you make a second memory for 1.78.
So most or us just use a 1.78 image area. if you can get another PJ and want to spend endless hours of set up and calibrating you can blend
| Posted: Fri Dec 17, 2010 11:14 pm Post subject: Re: Aspect ratios - what the heck? |
| Marcel_D wrote: | | I'll start by asking why? Why is this extreme aspect ratio deemed necessary for modern movies? |
The format works well with both our "panoramic" visual perception system and with theater projection systems and rooms.
The human field of view is nearly 180-degrees horizontal, but much less than that vertically. So, nearly 2:1. We're also used to seeing this way; looking around: Vistas, skylines, panoramas, and horizontal groups of people.
Also, if you think about the size and shape of a room, it's typically much wider than it is tall, so it works better with a wider/shorter screen than it does with a narrower/taller one.
Like Athanasios said, 2.40 works pretty nice in a 16:9 screen. There is lots of 16:9 content, especially if you watch any HDTV. Plus, some newer animated movies and movies made for 3D are often 16:9... Avatar, for instance. The last Batman movie - Dark Knight - also switches aspect ratios between scope and IMAX 16:9.
I wouldn't worry about 4:3... Even if you do watch it, it's probably of lower-quality and would benefit from being smaller on the screen anyway.
