Anyone know if Barco 1200 H card is compatible with 1208?
RVonse
Posted: Sun Dec 05, 2010 9:17 pm    Post subject: Anyone know if Barco 1200 H card is compatible with 1208?
I am wondering if a Barco 1200H card (part number R762108) can be put in place of the Barco 1208 H card (part number R7621085)? Or will it blow up the projector and cause smoke and other bad things to happen?
jkruger
Posted: Sun Dec 05, 2010 9:56 pm    Post subject:
And does it fit the 1209s as well?
Posted: Sun Dec 05, 2010 10:00 pm    Post subject:
It will indeed fit both, but the '5' designation means it's a later board and is built a lot better than the older 1200 board. I am clearing out the newer boards at $50 if you're interested..
RVonse
Posted: Mon Dec 06, 2010 2:48 am    Post subject:
Thanks Curt. Yes I think I will get one from you.
My projector died a couple days ago but fortunately I had another spare H board. But even though the spare H got me up and running again I notice some distortion on the left side of the picture that I never saw before. So I suspect the 2nd board might be partially defective too. I guess I won't know for sure until I get another board to try. And even if it is a good board I still would like another good spare.
I have always ran width at the absolute maximum so that probably puts a strain on this card too.
I'll send you an email Curt.
RVonse
Posted: Mon Dec 06, 2010 9:41 pm    Post subject:
Here is an update.
I was able to fix my old H card by using a part from another Barco 808 H module. After I installed the part (mosfet) in the old H card the projector works fine again. But I still see the same distortion. But I am getting off topic to this thread so I will start another.
