| Posted: Sun Dec 05, 2010 6:31 pm Post subject: P16LXV43HKA pinout guestion |
This was used in a Barco Cine 8 made in about 2004.
secstate
| Posted: Sun Dec 05, 2010 7:56 pm Post subject: |
I am pretty sure they are the same as the MEC 180DVBs, P16LNPs, and P16LNQs. If you have an example in hand it is pretty to compare. I know one of the European Barco guys (Ile?) has used them and probably knowns for sure.
secstate
| secstate wrote: | | I am pretty sure they are the same as the MEC 180DVBs, P16LNPs, and P16LNQs. If you have an example in hand it is pretty to compare by looking at the tube neck. I know one of the European Barco guys (Ile?) has used them and probably knowns for sure. |
| Posted: Sun Dec 05, 2010 8:44 pm Post subject: |
Thanks I was thinking the same thing. I was also trying to figure out the bias voltage and that would put it at about 132V .
Ile
| Posted: Mon Dec 06, 2010 10:40 am Post subject: |
Newer heard, but I guess pinout is same that other 8" MEC tubes in 808 and cine8.
What do you mean by 132V bias voltage?
Heater voltage should be 6.3V, measured between -fil and +fil.
Floating around 100V, measured between ground and -fil.
Hulio
| Posted: Mon Dec 06, 2010 7:59 pm Post subject: |
Here a description of the RGB amplifier, if it helps. If i'm not wrong, the tubes are P16LXW instead of LXV.
Stan
| Description: |
 Download |
| Filename: |
Output amplifier.pdf |
| Filesize: |
46.47 KB |
| Downloaded: |
5713 Time(s) |
| Posted: Mon Dec 06, 2010 8:36 pm Post subject: |
| Ile wrote: | Newer heard, but I guess pinout is same that other 8" MEC tubes in 808 and cine8.
Floating around 100V, measured between ground and -fil. |
The bias setting is for the Sencore CRT tester.
