Barco Cine7LT HDFury3 Setup Help
moli73
Posted: Wed Nov 24, 2010 12:09 pm    Post subject: Barco Cine7LT HDFury3 Setup Help
Hi All,
I recently picked up the HDFury3 and was wondering if any one can help with the correct or best way to plug the cables into the Barco.
I can only get to 720p with a great pic but not 1080i. At 1080i the screen is very dim almost noy visible.
Your help would be very much appreciated.
Moli
roose.r
Posted: Thu Nov 25, 2010 10:59 am    Post subject: cine 7
first, is it possible to have 1080i, 1080p on a cine7
if yes, you need a gammax and feed de cine 7 rgb signaal, i had the same problem with a cine 8 (very dark image)
with the gammax you can boost the "white" in the image.
the gammax is availble with the hdfury3
grtz
moli73
Posted: Thu Nov 25, 2010 11:33 am    Post subject:
The Cine7LT can only get to 1080i. I have the GammaX as well so l will try with this and see how it goes.
joatmon
Posted: Thu Nov 25, 2010 4:10 pm    Post subject:
Your horizontal phase adjustment might be too low. As you ramp this up and down the image will dim (and if you have it too low on the edge the picture will dynamically dim)
I have a Runco DTV-940 (very similar to your Cine7) with a Fury2 (no gammaX). 1080i will end up being about 5% overscanned (at least on mine it has to be). I personally prefer the 1080i over the 720p.
Just to be clear on this as well, I see no brightness difference between 1080i and 720p (both are set to around 55 contrast and 53 brightness)
moli73
Posted: Sun Nov 28, 2010 6:54 am    Post subject:
Tried this with Gamma and can only get 720p and a very dim 1080i. Also added a BNC connector with the cable but still no help.
ANy ideas anyone on how to fix this?
joatmon
Posted: Mon Nov 29, 2010 2:31 pm    Post subject:
I don't know what to suggest other then reseting the memory block associated with 1080i and starting the 1080i setup over again. My Fury2 is connected to my DTV-940 via the 5 wire RGB input. Perhaps make feature like your line tripling is turned off?
Entertained by a Runco DTV-940 (aka Barco Cine7/708)
roose.r
Posted: Tue Nov 30, 2010 8:54 am    Post subject:
i connected on the db 9 (port3 on the cine8)
moli73
Posted: Wed Dec 01, 2010 8:13 am    Post subject:
The Cine7LT has NO db9 input only RGB or component. Still no luck with getting it to 1080i
Ile
Posted: Wed Dec 01, 2010 10:41 am    Post subject:
Have you tried to set gammax to negative sync from side switch?
Have you set Hphase correctly? Sometimes when it's way off picture is dim and is cropped from left or right side.
Adjust picture width smaller and go to Hphase setting. Adjust contrast to 10 and brightness to 70. Now you should see if there is any raster at picture left/right sides, when you look to tube through lens. If there is, you can adjust picture to little right from center using arrow keys. Still leave little raster to right also.
http://www.curtpalme.com/images/tuberastersetup4.gif
Then adjust picture width back to normal and center picture with raster sift.
If there is no raster at sides of picture, problem is your source. Many today sources have too small porch settings for analog crt with 1080i/p. If your player have 50/60 Hz refresh rate alternatives you can try other one, to see if there is any difference. Try with other source or with scaler if possible...
