rwallmow
Joined: 19 Jul 2010 Posts: 29 Location: Minneapolis, MN, USA
| Posted: Thu Nov 18, 2010 3:52 pm Post subject: HV arcing? or something else? |
I have been watching my BG 801s a lot more lately and while its never had a HV shutdown, every once in a while (maybe once per hour at most) there is a small "tick" noise (I am thinking a small HV arc) and associated with that noise is a flicker of the color in the over all picture (for a split second the pic has more of a blue tint). Its definitely not a large enough arc to cause HV shutdown, nor is it loud enough to hear except when sitting right near the PJ.
My main question is if this is a HV issue, do I need to replace my HV leads or is there a way to insulate them (I know electrical tape would NOT do it, its only rated usually for like 4-600volts)? Also is there a way to pinpoint WHICH lead is arcing, since I have never SEEN an actual arc, nor do I see any damage to any of the leads?
_________________ Long time LCD/DLP user (dating back to the 90's) tired of lamps, DLP rainbows, and screen door look of LCD, took the plunge with a dang near new BG 801s (no wear on tubes at all)
| Posted: Thu Nov 18, 2010 4:01 pm Post subject: |
No, hte HV leads are fine if it's only a 'tic'. A 34KV HV arc would be a BANG!
You have arcing of a much lower voltage. Suspects would be a CRT socket or the focus block, maybe the HV quadrupler (but probably not the quad).
I'm blowing out all Barco 800/801 parts dirt cheap as per my next mailout on Monday, so it shoudl cost you next to nothing to repair this.
rwallmow
| Posted: Thu Nov 18, 2010 5:41 pm Post subject: |
| Curt Palme wrote: | No, hte HV leads are fine if it's only a 'tic'. A 34KV HV arc would be a BANG!
I'm blowing out all Barco 800/801 parts dirt cheap as per my next mailout on Monday, so it shoudl cost you next to nothing to repair this. |
Talk about timing, I will wait for the pricing on your next mailing
JustGreg
| Posted: Thu Nov 18, 2010 8:22 pm Post subject: |
My 8500 just started doing something similar. A tic, no pic, and then the pic expands back slowly.
_________________ Greg
| Posted: Thu Nov 18, 2010 11:11 pm Post subject: |
In the case of the 8500, you most likely have an HV overload, or you could have a problem in the HVPS. LEt me know if you want to send me the HVPS for testing here.
rwallmow
| Posted: Fri Nov 19, 2010 9:07 pm Post subject: |
I might need more parts now, last night I was watching a movie and all of a sudden the convergence looked off to me, upon further investigation the top and bottom of the picture on the green tube have bowed in, and I have lost ALL bow control in the menus, I am not sure which parts controls this, if this is convergence board failure or magnetics, or what, I am new to CRT projectors, but completely comfortable with a soldering iron (I have recapped PC motherboards in the past, its not fun, but its cheaper than a new motherboard).
rwallmow
| Posted: Fri Nov 19, 2010 9:10 pm Post subject: |
On a side note, while my BG801 is a baby hour wise and a "9" on the tubes, it is sure showing its age with problems and failures, but unlike a LCD its actually worth fixing
