VGA display
bilideya
Posted: Fri Nov 12, 2010 5:53 am    Post subject: VGA display
Is it possible to wire a laptop display into VGA, DVI or other? I'm doing a project that needs a 15" laptop screen. Simply yes or no, can i rewire the infomation cable into a VGA or DVI? I know what i have to do with the power, but i meed to know if this is possible.
_________________________
yahoo keyword tool ~ overture ~ traffic estimator ~ adwords traffic estimator
Wombat
Posted: Mon Nov 15, 2010 5:50 am    Post subject:
No. It's almost certainly cheaper to buy an LCD monitor.
There are industrial PC video cards that support panels, but they cost several hundred bucks, and you need to be sure that a card supports your particular LCD panel. A cheaper way is to buy an embedded PC motherboard that has a built-in LCD display controller. These could be under $50 for a surplus or obsolete one, but again, only a limited number of panels will be supported.
The best compromise might be to mutilate a working but obsolete laptop. PIII and P4 class laptops are obsolete by business standards, but are capable of DVD playback (and SD MPEG4 with a P4).
