G70 tilt angle
nemmi69
Posted: Wed Nov 03, 2010 1:33 pm    Post subject: G70 tilt angle
Does anyone know what the maximum angle the unit can be tilted at and still be able to correct the keystone effect?
cheers
What doesn't kill you is only biding it's time
jeffslife
Posted: Wed Nov 03, 2010 2:15 pm    Post subject:
I wish I knew.
I am still trying to figure an ACCURATE way to measure the angle.
GOOD LUCK
We are ALL job creators !
nemmi69
Posted: Wed Nov 03, 2010 3:02 pm    Post subject:
I have a bubble protractor for that.
jeffslife
Posted: Wed Nov 03, 2010 11:23 pm    Post subject:
where did you get it? roughly what cost?
Posted: Wed Nov 03, 2010 11:26 pm    Post subject:
I think some experimenting with PJcalc may give you the answer. You can download it in the manuals and downloads section for the G70 on this site.
nemmi69
Posted: Thu Nov 04, 2010 10:16 am    Post subject:
you can find protractors on ebay. Around £20
virusc
Posted: Thu Nov 04, 2010 2:28 pm    Post subject:
I think it is recommended no more than 15ish. The G70VR I think had more electronic correction. The more tilt, the harder on stability and less phosphor gets used. It may be possible to modify that adjustment with a resistor like the marquee squeeze mod to get more permanent range but I would not recommend anything but standard tilt (default angle level on bracket, 11degrees?) to maximize phosphor usage.
Posted: Fri Nov 05, 2010 4:40 am    Post subject:
Id be mounting lower and tilting the front up if anything, all youll do be pointing the front down is wear the phosphor on a bad angle which will mean you wont be able to set it up with the same tubes and stay in the wear patern later without moving it too far back and using less phosphor.
The squarer you get it on the tube faces the better.
