NEED A NEW HD TUNER ANY ADVICE?
jeffslife
Posted: Mon Nov 01, 2010 2:05 am    Post subject: NEED A NEW HD TUNER ANY ADVICE?
My samsung ts160 tuner wont switch to 16:9
It shows up in the menu but stays in 4:3
I would also like to eliminate the dvi and have hdmi out
but I really dont want to spend a fortune
all suggestions and reasons are appreciated
We are ALL job creators !
dvh99
Posted: Mon Nov 01, 2010 2:20 am    Post subject:
http://www.dream-multimedia-tv.de/
dreambox 8000
jeffslife
Posted: Mon Nov 01, 2010 4:00 am    Post subject:
I dont read german anymore but it looks expensive.
maybe something a little further down the price ladder.
dvh99
Posted: Mon Nov 01, 2010 2:37 pm    Post subject:
dm800 then you can choose the english language by clicking on the british flag.
dm800hd se, has hdmi out.
jeffslife
Posted: Mon Nov 01, 2010 3:25 pm    Post subject:
what about a samsung ts 360?
jkruger
Posted: Mon Nov 01, 2010 3:39 pm    Post subject:
I have used the ts 360 and had good luck with it.
fuzzybee
Posted: Mon Nov 01, 2010 5:01 pm    Post subject:
http://www.crwww.com/232-ATSC+.asp
We use these at work all the time.
Posted: Mon Nov 01, 2010 7:07 pm    Post subject:
How much are you paying for those?
Not sure about cheap, but Channelmaster has a DVR/OTA for I think $300.
jeffslife
Posted: Mon Nov 01, 2010 8:29 pm    Post subject:
Dont need dvr just HD OTA with HDMI out
dvh99
Posted: Mon Nov 01, 2010 9:46 pm    Post subject:
http://www.techradar.com/reviews/audio-visual/digital-tv-recorders/vu--duo-698755/review
this one has very good reviews and is supoposed to be a dreambox killer price wise.
linux system so cardsharing is an option.
banzairun
Posted: Mon Nov 01, 2010 10:31 pm    Post subject:
If you want something cheap with HDMI, maybe dig up a used Samsung DTB-H260F. It has HDMI out.
I had a 260 a while back on a direct-view CRT set and it worked great.. The tuner I was using for the main projection rig for a long time was the TS451, which was the 260's predecessor that has DVI-out (though I was only using the VGA). The 260 has no VGA, just HDMI.
The 451 I have developed a strange issue and just says "boot" forever -- It looks like it has a large BGA IC inside so I'd bet that poor solder is the culprit and it wouldn't be an uncommon problem with the 451..
After the 451 failed I went back to an old 160 which has the same issue you have, I've just been living with it since I watch very little TV anymore.
Given the choice, I'd dig up another 451 (or a 260 for HDMI) over a 160 or 360.. scan ebay & CL, you can probably find one for <$50.
jeffslife
Posted: Tue Nov 02, 2010 1:40 am    Post subject:
what do you like about the 260 over the 360? I dont want the 451 as I want hdmi out.
banzairun
Posted: Tue Nov 02, 2010 6:25 pm    Post subject:
The 260 is an OTA tuner only. It's small and a later model than all the rest of them, interface works well.. the 360 is a sat/OTA combo like the 160.
jeffslife
Posted: Tue Nov 02, 2010 11:27 pm    Post subject:
Thanks for the info
Posted: Wed Nov 03, 2010 10:32 am    Post subject:
I have a Samsung 260F, awesum tuner, it does OTA and Clear QUAM cable too. 480/720/1080i outputs and it can power an HDFury1 without a power supply.
When I had it here hooked up to Cable I also got all the digital music channels. Unfortunately not one single free QUAM station ( thanks Rogers you cheap bastards! ). OTA stuff worked great. It's a 4th gen tuner I believe, it picked up far more OTA stations than 360. With the same antenna. Just MAKE SURE to get the remote with it. There are no buttons on the box so the remote is a must.
