Is there an iMac guru in the house?
Posted: Thu Oct 28, 2010 8:32 pm    Post subject: Is there an iMac guru in the house?
I have two very similar iMac G5s, both 2ghz, both OSX 10.4.11. When connecting by Firewire and following the steps in Migration Assistant, I get no disks appearing on the destination machine, I get Cannot Connect error message, any ideas? Ethernet would not connect, or I am doing it wrong. The source machine will not burn DVDs so that option is out.
MikeEby
Posted: Thu Oct 28, 2010 8:36 pm    Post subject:
What about a USB Flash drive?
Posted: Thu Oct 28, 2010 8:41 pm    Post subject:
That might work!
Posted: Thu Oct 28, 2010 8:52 pm    Post subject:
hmm, the Migration assistant should work, did you follow the direction correctly?
Posted: Thu Oct 28, 2010 9:39 pm    Post subject:
Tim, are you putting the source iMac in FireWire Target Disk mode?
Posted: Thu Oct 28, 2010 10:02 pm    Post subject:
Yes and Yes. Just got back with a USB flash drive, it appears to be copying okay, let's see if it will install to the other hard drive too.
Posted: Thu Oct 28, 2010 11:00 pm    Post subject:
A big thanks to Mike Eby, the USB did the trick, none of thee iMac "experts" here locally suggested that, probably because they would not make any money with it.............
